Old 09-28-2005, 10:41 PM   #1
wolfthing2000
Kick panel repair
I am finishing up the repairs on floor and "A" pillar area and remember seeing a photo of a repair done in this area where the bottom of the kick area was left open. Does anyone have ideas on this or should I just weld it all back shut in this area?????
wolfthing2000 is offline   Reply With Quote
Old 09-28-2005, 11:57 PM   #2
4x4Poet
I don't understand what you mean, exactly, from your word picture. The bottom of the kick panels are, in effect, clamped between the A-pillar and floor/"inner rocker".
As for the bottom edge of the kick panel, I only saw spot welds affixing the kick panel to the floor near the side to tranny hump floor seam (accessable with the front fender off) and spot welds affixing the k-p to the lip on the rocker that holds the door rubber.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 09-29-2005, 09:13 AM   #3
motocrosschump
Gibbs Oil...!!! lol... I am just messing ..Weld that mug back up
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 09-29-2005, 04:46 PM   #4
wolfthing2000
Well, what I remember was an opening at the bottom about 1/2 to 3/4 inches high between floor and kick panel. In other words the kick panel stopped short of meeting the floor.
I believe I will just weld back to the floor panel.
Old 09-29-2005, 05:36 PM   #5
raggedjim
raggedjim's Avatar
I replaced mine but I cut off the door pillar, cut off the kick panel then welded in a new kick panel and door pillar. The order from inside-out at the bolt area is front fender mounting tab, front cab support, floor panel (also called inner rocker), kick panel, then the door pillar. I may be able to come up with a picture of this if you need it.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 09-30-2005, 04:12 AM   #6
4x4Poet
I gotcha Wolf. You mean the space between the floor and where the kick panel wraps under. The factory used a moisture absorbing sealant between the floor and the kick panel that made that area vulnerable to rust. Same sealant as what's between the floor and fire wall seam. Open cell foam is what it looks like. Says, "Come rust here!"
I would shoot some flexible, water-impenetrable sealant inbetween there. Welding the edge won't seal farther back in the gap and welding would burn any sealant effort. POR 15's PorPatch comes to mind, but other sealants would do well, no doubt. Affix one of those conical nozzles to the tube to get all the way back in there.
