My Ammeter Doesn't Work
All of the gauges in my 72 work fine, except for the Ammeter. Its not that big of a deal, but I would like for it to work. Are there any simple things that I can look for that might fix it? Is there a way to test the gauge?
49 Chevy 3100 69 Camaro Acro Sport II Biplane |
#2 | |||
Union Electrician
look under your hood on the drivers side by in the front corner and look a football looking black in line fuse holder, and there is another one like it near the battery on the passengerside. that is what I would check first, and the fuse shoukd be 3-5 amp...Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
An American Soldier
![]() Join Date: Feb 2005
Cameron, I have the same problem. Both my fuses are brand new. The entire wiring harness is brand new, but the needle on the amp gauge doesn't even hint at moving when I turn the key.
If someone knows how to bench test gauges...Amp, Temp, and the like, that would be awesome.
Dan dan.brue@us.army.mil |
Might check out this site:
http://www.fix-a-gauge.com/
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
An American Soldier
Thanks NeonLarry. I ordered the amp and temp gauge kits. It was only $18 with shipping. So, hopefully that will square me away on those two.
#6 | |
YES_____NO
![]() Join Date: Jul 1999
Let us know if they are worh anything. I for one like to see pictires of what I am buying.
![]() People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board |
#7 | |||
Union Electrician
I use them all the time and I really like the resistors they sell. I haven't used one of their ammeter kits, haven't needed any just my .02 Randy
Re: My Ammeter Doesn't Work
Really appreciate you guys. Found this thread using Google and the fuses were not present in my truck. 5 minute fix and my ammeter is working for the first time in 2 years!
Posted via Mobile Device Posted via Mobile Device
_____________________ Lou Axt, Jr. 1969 C10 Longbed 292 inline 6 Offy, Holley, true dual exhaust tows a 1966 Airstream Tradewind |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
The ammeters in our trucks are external shunt types so in order for them to work there has to be a shunt in the wiring between the battery and the alternator. If you rewire the truck and wire the alternator output wire to the starter or the battery you will have eliminated the external shunt and the ammeter will not work.
The external shunt is nothing more than a 12 gauge wire between the right fender terminal post and the alternator regulator battery junction in the left side harness. Here are 2 pictures to illustrate this. This is the shunt wiring and the fuses are circled in red. Here is the joint on my 67. It's the red wires.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
I've owned all together, past and present 8 of these old trucks and never had an ammeter work until I was informed about these fuses and the role they play. 3 of the 4 I have now have working ammeters. The 4th truck is for parts.
Worked for me! Replaced both fuses- one was broken, other fell apart, reconnected wire, my gauge works! That was the only gauge not working, I hadn't gotten around to figuring out why until I found this thread.
'71 ![]() '10 Dodge Charger SXT - DD '91 Kasel M101A2 3/4 ton trailer (It has Chevy rims!) |
C/10 junkie
Ok guys how about this? I converted my truck from idiot lights to gauges. Installed the fuses and my amp meter gauge worked great. Well I upgraded my old tired looking gauges with some nos units and now the amp gauge has zero movement. Checked fuses and fuses are good, bad gauge maybe? Whats your guys thoughts?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#13 |
I have a one wire alternator and no regulator. Should my gauge still function?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#14 |
![]() Join Date: Oct 2009
I have an internally-regulated alternator, and the ammeter does work, but the needle deflection is very small. For example, with the headlights on and the A/C blower on high speed (engine not running), the tip of the needle only moves about 1/8" to the left. Is this normal?
1971 C10 Longbed, 350/TH350 |
