chevy truck fan
motor mounts
all,
i am in the process installing my engine. i bought mounts from autozone (i know they are cheap) anyways i tried to put the bolt in the middle that goes to the frame, the bolt threads all the way in, but the bolt feels loose inside the mount itself even threaded all the way down ![]() thanks for the responses!!! ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Some of the cheaper mounts use different size bolts. I once bought two matching brand new in the box, exact same part, exact same brand number mounts at the parts store, and they used two different size bolts. One was 3/8 bolt and the other 7/16.
![]() ![]() Join Date: Jan 2005
I bought a motor mount from Autozone about a year ago. For some strange reason it had a metric thread in it. I think it was an M8.
![]() Join Date: Mar 2003
I got some about a year ago ---made in taiwan, had metric centers 10mm. I took them back. I got a trans mount that also had metric holes in it.
DON'T TREAD ON ME
![]() Join Date: May 2005
My mounts had a metric thread also. I took my Tap/Die set and rethreaded it for SAE threads and put a locknut on it just to be safe.
Old Yeller |
Vortec in the works
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
