Old 09-30-2005, 09:17 PM   #1
Z28Owner
Z28Owner's Avatar
Help with van tilt Please...
Hello, I bought a van tilt, and am in the process of installing it in my truck, but the wires are different colors from my truck, so how do I hook back up the turnsignals and stuff? My truck has the half moon style plug and the van has a blade style that is about 6 inches long. Thanks Truck is down till I get this figured out
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 09-30-2005, 09:20 PM   #2
jamie72
jamie72's Avatar
don`t cut the wires!! there is an adapter that just plugs in and its all good to go.
check with some of the truck venders on this board, they should have them.
good luck
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 09-30-2005, 09:36 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Or just go to the GM dealer and buy one. GM P/N 1894851 IIRC, it is less than 10 bucks.
Old 09-30-2005, 10:33 PM   #4
Jimbotronics
YA YA
Jimbotronics's Avatar
Solver posted step by step procedures in the FAQ section - it might be of some help to ya.. cheers, jim.
http://www.67-72chevytrucks.com/vboa....php3?t=133937
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 10-01-2005, 04:17 AM   #5
Z28Owner
Z28Owner's Avatar
Thanks for the part number Ill call around today and see if I cant find one.
1971 LWB Chevy C-10
350/350 3:42 eaton
Old 10-01-2005, 09:48 AM   #6
Canadian72GMC
I just finished doing this. Using a pick or a connector tool, remove the wires from the van column connector, and reinstall in the original truck connector. Write down the wire colors in the order they are in the truck connector, and just reinstall the van wires in the same location. I used the original truck signal switch so as to have the factory red hazzard light switch instead of the round black one from the van.
Canadian72GMC is offline   Reply With Quote
Old 10-04-2005, 11:04 AM   #7
Z28Owner
Z28Owner's Avatar
Hey Longhornman, can you post that part number in the FAQ, I tried but it wont let me reply, maybe you can edit your post. That seems to be all that is missing from that thread. Thanks again everyone.
1971 LWB Chevy C-10
350/350 3:42 eaton
Old 10-04-2005, 03:06 PM   #8
Longhorn Man
Hmm, I thought it was in there.
how much did it cost?
Old 10-04-2005, 04:36 PM   #9
Z28Owner
Z28Owner's Avatar
Depends on dealer around here I guess. Online its under $5.00 one dealer I called wanted $13, I ordered it yesterday and it came this morning for $9, at another dealer. Go figure?!
1971 LWB Chevy C-10
350/350 3:42 eaton
Old 10-04-2005, 04:40 PM   #10
Longhorn Man
at l;east it was cheap on every quote you got there.
Cool
Old 10-04-2005, 06:19 PM   #11
70short/step
70short/step's Avatar
Is it called "turn signal switch"? Thats what I got with that part number.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 10-04-2005, 07:01 PM   #12
Longhorn Man
Odd... http://www.gmpartsdirect.com/results.cfm
From www.gmpartsdirect.com
GM PART # 1894851
CATEGORY: All
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $8.67
OUR PRICE: $4.34
DESCRIPTION: HARNESS
