09-30-2005, 11:42 PM | #1 |
short or long water pump??
All original 71 3/4ton long bed, A/C, P/S 350/th350 do I have a short or long water pump? Starting a rebuild and am gathering parts. Thanks!!!
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
09-30-2005, 11:46 PM | #2 |
i think you have the long, but dont buy it because of my thought
-Steve |
09-30-2005, 11:51 PM | #3 |
Watch out for your cornhole !
Negative ghost rider, a 71 used short pump.
09-30-2005, 11:56 PM | #4 |
thanks, i know you can read the timing marks from the side, on my 84 K5 Blazer to read the timing marks you have to look down at the 12 o'clock position between the timing chain cover and the water pump, i believe that is considered the long pump.
10-01-2005, 01:25 AM | #5 |
i thought i might have got those backwards.....
-Steve |
10-01-2005, 09:16 AM | #6 |
DON'T TREAD ON ME
Should be a short pump. If you can put your hand between the pump and the timing cover its long, if not its short.
Old Yeller |
10-01-2005, 03:22 PM | #7 |
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
10-01-2005, 05:22 PM | #8 |
Thanks everyone, it is a short pump!!!
