Old 07-05-2002, 08:32 AM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
cooler thermostat?
I replaced the intake manifold on my truck with an aluminum Edelbrock manifold off my 77 Camaro. well, the engine gets real hot real quick and I was thinking I need to get a different thermostat. I saw that the thermos for our trucks are like 195 degrees. Wouldn't it be better if I went with a 180 degree unit instead, or maybe even a 160? Where could I get a 160 thermo?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 07-05-2002, 08:36 AM   #2
71Chev
71Chev's Avatar
You can pick up a lower temp thermostat at any part house.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 07-05-2002, 08:38 AM   #3
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
would you recommend the 180 or 160?
Old 07-05-2002, 08:42 AM   #4
71Chev
71Chev's Avatar
I run a 160.
Old 07-05-2002, 12:37 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
So do I. The Dyno sheet don't lie. It'll make more power.
Old 07-05-2002, 12:55 PM   #6
Wabash
Wabash's Avatar
in canada i run a 180 in winter and a 160 in summer
1972 C/10 LWB
1972 K/5 Blazer
Wabash is offline   Reply With Quote
Old 07-05-2002, 02:28 PM   #7
StingRay
StingRay's Avatar
If the rest of your cooling system is in good working order and you are not running wild compression, ignition retard, or very lean mixtures a 195 should be fine. Most new vehicles only come with 195 thermostats and will not run well if they have a different thermostat in them. I run a 195 all year round with no problem and it can very hot (100 degrees) here in the summer. A 180 will work fine for carburated vehicles but a 160 can actually cause your engine to run too cool.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 07-05-2002, 02:48 PM   #8
COBALT
COBALT's Avatar
I replaced my 160 (which had failed stuck open and my truck ran too cool) with a 180. So far it's great. Truck warms up fast, and I don't have to put up with waiting for an hour to get good performance out of it.
I'd go with 180. Good compromise.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 07-05-2002, 03:00 PM   #9
hanssolo
hanssolo's Avatar
I use a 160, I have 10:1 c.r. I had a '83 Bonneville once that ran at 220 and was the way it was designed. After 100,000 miles it ran like garbage and overheated. I dis-connected the computer, put in a 160 and it ran great.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
