Old 07-05-2002, 09:34 AM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
rearend ID
How do I tell what gears I have in my rearend? I have a 72 C10 with a 307.
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 07-05-2002, 12:34 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Pop off the cover and count the teeth. Divide one by the other (can never remember which is which) and that will give you the gear ratio. It's probably a 3.07. But your gear oil probably needs chainged anyways.
Old 07-06-2002, 05:52 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
the numbers you need wil be stamped on the very edge of the ring gear in plain view, may have to turn the gears a lil before you find the spot that they are stamped on on the gear.
the numbers of most importance will look like somethin like this: 41 - 9
and 3 - 16 - 72
if the 307 engine is wat truck originally came with then it will be 3.07 if with 4 speed or auto and 3.73 if with 3 speed manual without O/D
good luck
Fast68Chevy is offline   Reply With Quote
Old 07-06-2002, 06:28 PM   #4
JHickson6
I Love This Stuff!
JHickson6's Avatar
Another possibility would be to check the driver side axle tube for the stamped in axle code. Then take that code and find it on the chart below. This chart is off of www.americanclassic.com/paint.htm
1972 Rear Axle codes
Series Code Ratio Plant
1/2-Ton RAA 3.73:1 N/A
1/2-Ton RHA 3.07:1 N/A
1/2-Ton RHB 3.07:1 N/A
1/2-Ton RHC 3.73:1 N/A
1/2-Ton RHD 4.11:1 N/A
1/2-Ton RHG 4.11:1 N/A
1/2-Ton RHS 3.07:1 N/A
1/2-Ton RHT 3.07:1 N/A
1/2-Ton RHW 3.73:1 N/A
1/2-Ton RHX 3.73:1 N/A
1/2-Ton RHY 4.11:1 N/A
1/2-Ton RHZ 4.11:1 N/A
1/2-Ton RRR 3.07:1 N/A
1/2-Ton RRS 3.07:1 N/A
1/2-Ton RRT 3.07:1 N/A
1/2-Ton RRW 3.07:1 N/A
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 07-06-2002, 06:47 PM   #5
Fast68Chevy
pass side tube top front side of it about 4 to 6" from the edge of the cast iron center housing sleeve where axle tube enters, codes are also listed in the red book, which alot of us have handy
72 is the only 67-72 year with R codes, 70 and 71 are T codes, and 69-earlier are two digit codes
Old 07-07-2002, 06:04 PM   #6
JHickson6
I Love This Stuff!
JHickson6's Avatar
Sorry your right Fast68Chevy, the axle that i checked was upside down! Woops!
JHickson6
My Rides
