10-01-2005, 06:06 PM | #1 |
Frame rail width?
Hi guys, got a question for you guys. Does anyone have the exact measurements of a 72 4x4 blazer frame across the front wheels and also 76 two wheel drive pickup? I am looking at converting my 4x4 blazer to two wheel drive since I have my jeep to beat around in the brush in. A friend has 76 two wheel drive frame I can get cheap and want to make sure the width would be the same or if I have to find a 72 two wheel drive frame. Thanks for the help!
10-01-2005, 07:12 PM | #2 |
Someone else posted this link a while back. Useful stuff.
http://www.chuckschevytruckpages.com/framespecs.html |
10-01-2005, 09:34 PM | #3 |
It will not work. You need a 2wd Blazer frame
10-01-2005, 09:54 PM | #4 |
Project Junkie! Fishing Poor!!
Lots of guys have converted 4X4 Blazers to 2X4. You will need the frame horns also to use as templates to drill the holes that you will need to drill to mount the front crossmember. You can use one up to 1987. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
10-01-2005, 11:04 PM | #5 | |
Where's my beer?
ascuro, that site hasn't been posted in a while,your join date was 10 days ago, How do you know this site was posted here a while ago? are you using a ghost account now?
Paul How do you make the invisible, visible?.........You take it away. |
10-02-2005, 10:59 AM | #6 |
Well, then I probably saw it on the CK5 forums. Why the paranoia? Just trying to help out. So sorry, heh.
10-02-2005, 11:12 AM | #7 |
Hey WES I think he wants to use the entire frame setup from the 76 model frame, not just the front crossmember.
10-02-2005, 11:16 AM | #8 |
Dutchboy,
This link might help. http://67-72chevytrucks.com/vboard/s....php3?t=170798 Marianne and Curt
1975 GMC Jimmy Full Convertible 4x4 - For Sale |
10-02-2005, 12:14 PM | #9 |
72CSTC5 you are wright, he wouldn't want to use the entire frame. Not at least on a 2 wheel drive. That would require the use of a body lift... It would be a lot better to just use just the front crossmember... I hope that I didn't throw confusion into the situation...lol WES www.ClassicHeartbeat.com
10-02-2005, 08:59 PM | #10 |
Just wondering if the widths of the frames above the front wheels are the same between the 76 2wd pu vs 72 4wd blazer. I know how to handle the rearend (flipping the axle and set pinion angle as a step until fullfour link and air bags) and how to route the steering and such just need to know whether I can utilize the 76 crossmember or if I need to hunt down a 72 crossmember. The chart with the measurements show the frame widths at 28" above the front wheels, whereas measuring my blazer I get roughly 28 1/2" (motor is still in blazer so can't get the tape measure perfectly flat between the two measuring points).
10-03-2005, 10:50 AM | #11 |
Dutch, it will fit...
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
10-03-2005, 02:36 PM | #12 | |
The LuvShack Garage
Kurt, VTBLAZER, posted it here a little while back, not sure of exact date. And he, ASCURO, may have been a guest for the last year or so who knows
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 10-03-2005 at 02:38 PM. |
10-03-2005, 03:02 PM | #13 |
If you want to just change out the front crossmembers they will fit. I used an 87 suburban crossmember complete in my 2wd Blazer.
10-04-2005, 09:12 PM | #14 |
Thanks guys for all the info! Want to get my ducks in a row before I tear into a perfectly fine 4x4 to satisfy my streed rod fetish my JEEP Wrangler can't fulfill.
