72 Cheyenne
I lied, I have a few,
The hose was hooked up to the Intake, can it be redirected to somewhere else? The Carb? How can you tell other than your brakes not working that the booster is bad? My brakes did work. What tips can you give me on changing it myself? It seems pretty easy. Thanks guys. ------------------ 72 Cheyenne C20 Built 350/T350 AC/PS/PB/AT Dana60 Leaf Factory Saddle Tanks San Diego, CA Pics of My Truck <A HREF="http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src= ph&.last=1" TARGET=_blank>http://photos.yahoo.com/bc/aikidojiujitsu/lst?.dir=/Chevy+Cheyenne+C20&.src= ph&.last=1</A> |
its all about the +6 inches
If the pedal was real hard to press down, it is dead.
The booster hose can go to the carb, if you have a large port, and it is below the throttle blades. As for tips, do not rush. And do not open the master cylindewr's hydralics...it is not neede. However, be sure to support it the wqhle time you are working. Gently pull it away from the booster, and hang it with a rope or something. (You can tie i to the hood, that's how I did it...with a bunjie cord too) ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
I am in the middle of mine as I type this, The clip that attaches the pin holding pedal rod is a pain. So is the pin. A punch and hammer will be needed...WD-40 too.
