Old 10-02-2005, 09:26 AM   #1
jec
jec's Avatar
Whats it worth? NOS NP241C
I have a brand new NP241C transfer case that has never been installed in a truck. I acquired at a dealership auction in the early 90's. At the time, I drove K5 Blazers and wanted to keep for a spare.
The numbers on it are as follows:
241C
Model - 1563 7131
Serial # - 58 941
Ratio - 272
Would like to trade for NP205 with adaptor to fit TH400. I am located in Ohio.
jec is offline   Reply With Quote
Old 10-02-2005, 11:01 AM   #2
Is this for a solid axle(right drop) or IFS(left drop)?
Old 10-02-2005, 02:22 PM   #3
jec
jec's Avatar
It is a right (passenger side) drop.
Old 10-02-2005, 07:54 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Jasper wants 1300+ for a reman. Transfercase express wants $895 new, 595 reman. exchange. Does it have a mechanical speedo or the VSS? Pass side drop 241s were only around for a couple years. I believe it uses the same trans adapter as a 208. Anybody else know?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-03-2005, 08:45 PM   #5
jec
jec's Avatar
I checked the transfer case tonight. It does not have a mechanical speedometer.
There is a two (2) pin connector near the shift arm. I guess this is for the electronic speedo.
Old 10-03-2005, 09:51 PM   #6
Jasper wants what?!!!I bought one from GM in a crate,new for under $900.So jec,where are you located?
Old 10-04-2005, 12:42 PM   #7
jec
jec's Avatar
Special -K,
I am located near Cincinnati, Ohio.
Do you have a NP205 that will bolt up directly to a TH400 without a coupling?
I have seen the transfer cases with a female 32 spline input made specifically for the turbo 400 applications.
Let me know.
Old 10-04-2005, 01:35 PM   #8
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
That 2 pin connector is for the 4wd idiot light in the dash.
Old 10-04-2005, 02:59 PM   #9
Dean
Dean's Avatar
What part of Cincy JEC? I'm in Batavia.
Dean is offline   Reply With Quote
Old 10-08-2005, 01:05 PM   #10
What I have are all 70-72 vintage mated to TH350.Not sure what it takes to mount the TH400 or the spline count.
Old 10-08-2005, 09:32 PM   #11
jec
jec's Avatar
Check the NP241C and found the mechanical speedometer connection. As I stated before, there is also a two (2) pin electrical connector that was identified as the 4WD switch by another member.
Old 10-09-2005, 06:43 AM   #12
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
th350, will be 27 splines and the th400 will be 32 splines.
Old 10-24-2005, 06:45 PM   #13
hifiguy
Re: Whats it worth? NOS NP241C
Do you still have that 241 case around? I may be interested in buying it or trading for it. My '68 burb has a turbo 400 with an np205 fixed yoke in it - 32 spline. I think that's what you're looking for. The only problems are that's my daily driver and I live way over in Arizona. But maybe we can work something out - if you still have it.
hifiguy is offline   Reply With Quote
Old 10-25-2005, 10:44 PM   #14
Smokin85
the np241 and np208 are basicaly the same t-case the np241 is a newer version of the np208
Smokin85 is offline   Reply With Quote
