Old 10-02-2005, 09:38 AM   #1
Jason71k10
ready for reassembly
Jason71k10's Avatar
bent axle
Well i discovered that I have a bent rear axle shaft on my k-10. It's bent near the mounting flange, but for some reason I can't feel any wobble when I drive down the road, yet when I look at the wheel in the mirror, it's wobbling like crazy!!
Anyway, I want to know what parts will interchange with my axle. The truck has a 12 bolt rear with the skinny 2" drums. Will axles from any 12 bolt fit, or will the narrower drums need a shorter axle shaft? I 've thought about just swapping the whole rear end, but If I can just put in a new shaft that would be better. thanks for any help
I know this isn't the 4x4 board, but since it's a rear axle question, I posted it here also.
Jason
stock 71 4x4
2003 Jeep Liberty, rocky mountain edition
I'm obsessed, and wouldn't have it any other way!
Jason71k10 is offline   Reply With Quote
Old 10-03-2005, 06:17 AM   #2
JimKshortstep4x4
Talking
Since you have 6 lug axles you will want to get an axle out of a 71 up through 78 4x4 12 bolt rear end for a replacement. Some 70 4x4's have the longer axle that was in the 71 and later but you will want to measure as 70 was a change year.
If you buy a used axle, be sure to check the bearing surface for pitting or spalling. Also if you roll the axle on a flat surface you can tell whether it is bent or not.
Jim
Old 10-03-2005, 11:19 PM   #3
Jason71k10
Jason71k10's Avatar
cool, thanks Jim. A friend of mine junked a 12 bolt from a 78 a couple days before we discovered it was bent.......bummer
stock 71 4x4
