10-02-2005, 08:16 PM | #1 |
PROJECT 7DEUCE
Hydro clutch ? Anyone have one in there truck?
Has or does anyone have a hydro clutch set-up in there truck a friend of mine it wanting to convert ot a hydro set-up and needs a direction to head any help would be great..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-02-2005, 08:51 PM | #2 |
Had one for 6 years on my 72 2wd cheyenne. Used a trans from a 96 chev truck with hydro clutch. Mounted the master cylinder behind brake boster using the original manual clutch linkage rigged to activate. The 5 speed worked great but the clutch was a bit hard to push in.
10-02-2005, 10:47 PM | #3 |
Embrace the Redneck
what does that look like? i'm thinking of buying a 5 spd from a 92 chev pu. and i'm lery of the hydro clutch as i used to have one and about once a year i'd have to replace something in it b/c i blew out an oring.
'01 Camaro Son, you just can't get there from here... |
10-02-2005, 10:56 PM | #4 |
Merciless Butcher
If you don't want to cobble one together out of used parts, check out the setup from McCleoud. It uses a hydraulic throwout bearing..Summit carries it..It's pretty sweet.
Your Bought And Sold....I Got Your Soul! |
10-03-2005, 01:41 AM | #5 |
Embrace the Redneck
i've had a jeep w/ the hydro bearing it in it and it is the smoothest by far but if you're hard on them like i am when it comes to shifitng. they have a tendency of blowing out a couple of orings a year and they cost alot to replace, not counting the time to remove the tranny to replace the bearing.
my .02 sswj
10-03-2005, 11:07 AM | #6 |
Post Whore
I'm using a hydraulic clutch and hydroboost from a 1989 1 ton. Here is a link to info on my swap. Hydraulic Clutch and Hydroboost
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
