10-02-2005, 09:49 PM | #1 |
Tire and wheel recommendations **Sorry..another wheel thread**
My tires need to be replaced (not because they are worn out, but rather because the rubber is old and is splitting and cracking). Well, since I need 4 new tires, I want to replace the rims too. The truck is a 71 C20 with stock 16" rims.
I read through the sticky thread with a bunch of wheel pictures, but the vast majority are either 15" or on trucks that have been lowered (a lot). So....on to my question: What would be the best stock(ish) replacement? I am not going to lower the truck (ever), and I want to put on the tallest tire for gearing reasons (4.11:1 rear). So I am thinking 17 inch rims will give me the best options for taller tires (15" won't fit over the calipers afaik). So...what backspacing and width would be ideal? What size tire would be best? I was thinking 275/70-17s? Here is a photo of the truck now (you can see the need for decent rims and tires!!) Sorry for another wheel and tire post, but I cannot find anything pertinent? Thanks, Tim
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) Last edited by Tim240Z; 10-02-2005 at 09:50 PM. |
10-02-2005, 11:28 PM | #2 |
Got Big Block?
my 285/60/17's are close to 31" tall I think.... (pic in my sig)
"Experience is what you get when you didn't get what you wanted." |
10-03-2005, 12:37 AM | #3 |
What are the specs on the rims? (Width, BS etc)
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
10-03-2005, 08:24 AM | #4 |
If your truck is 8-lug, why don't you go with the late model aluminum 2500HD wheels with a 285/75/16 tire? IMO I think they're the best looking wheel to put on a 3/4 ton truck. I'll try to find a pic and post it later.
10-03-2005, 09:02 AM | #5 |
Got Big Block?
285/60/17 on 17x9.5's with 5.5" backspace on the rear. 255/60/17's on 17x8's with 4" backspace on the front.
10-03-2005, 09:13 AM | #6 | |
Purs: Thanks for thos specs. Would I be able to go 17 x 8 with 4" BS at all 4 corners?
