10-02-2005, 11:14 PM | #1 |
smelly cab
My cab stinks like gas when it is full upon checking just after fueling looks like it is leaking from around the sending unit is this an easy fix? Also If I dont fill it full will it not leak out there?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
10-02-2005, 11:17 PM | #2 |
Yeah it is easy just unscrew the ring should have a bout 4 or so tabs on it and unlock it.You probabally need a new o-ring there,wouldn't hurt to put a new sock on the sending unit at this time either.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
10-02-2005, 11:20 PM | #3 |
its all about the +6 inches
Or just remove the sock, why put a filter in the tank and make it a PITA to replace?
not filling it up all the way is a good thing to do untill you can fix it. it is probably venting into the air in the cab and you just don't quite notice it yet. |
10-02-2005, 11:21 PM | #4 |
Where's my beer?
If that fails you can use one of these...
Paul How do you make the invisible, visible?.........You take it away. |
10-03-2005, 01:03 AM | #5 |
Re: Royal Pine
Actually, I had the same problem at one time (before teardown). I used Royal Pine air freshener to "mask" the smell. Believe it or not, it worked.
'71 Chevrolet C10 shortbed - 414" LQ9/4L80e/S91 turbo --- PROJECT! '99 Chevrolet Camaro Z28 A4 Yank 4200 stall/AZPS 03 cam (242/248 .621"/.615" @ .050" lift)/UMI 4130 suspension/True Duals/Moser 9" 3.73/AR Torq Thrust M's Black |
10-03-2005, 07:52 AM | #6 |
ok can I get this oring from autozone? also if I dont fill full will it stop leaking if the fuel is not up that high? About how much less will get level below sender?
10-03-2005, 09:22 AM | #7 |
also after looking at it I see the locking ring. If I tap that out is it the only thing holding the sending unit in? Thanks
10-03-2005, 09:59 AM | #8 |
Yes, it has been a while since I've had to do it, but you tap on the tabs (I use a flathead screwdriver and hammer) and the ring should turn until it reaches a point where it will come out of the slots. I believe it tuns counterclockwise to come off.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-03-2005, 10:00 AM | #9 |
Java Mechanic
Light a match and see if the smell goes away.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
10-03-2005, 10:07 AM | #10 | |
Born a Chevy Man
I know panhandler62 is joking, but I really hope you are not smoking with this problem in the cab. That would be
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) CHEVY, American made w/pride! If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
10-03-2005, 11:36 AM | #11 | |
Still Green but learning
Works with the Gas smells in my house
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
10-03-2005, 12:12 PM | #12 |
No I do not smoke. Does anyone know if I dont fill it up all the way it will not leak out of that unit right? This is the first time I noticed it in 3 weeks but it was the first time I fill it really full. Want to make sure it did not just start. Also I dont think the fumes are that bad they would ignite I see people smoking at the gas pump all the time.
But anyway. And were can I get this o-ring from?
10-03-2005, 12:20 PM | #13 | |
67 is sold
Sounds like the best info is posted above on this one. Just a little maintenance is all you need
10-03-2005, 12:24 PM | #14 | |
The complete repair can take as little as 5 minutes if you have the o-ring and can get your seat out of the way. Make sure the doors are open and the cab is well ventilated. Use a rubber mallet.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
10-03-2005, 12:44 PM | #15 |
Where's my beer?
you can get one from Athey's (Bill is a vendor on this board), i'm not sure if autozone would have one or not, but it might be worth a try.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
10-03-2005, 01:44 PM | #16 |
How can I get in touch with athey's or bill to get one? also do I have to remove the whole unit it is a new sending unit.
One other question I have a reciept were he got a new sending unit and tank but did not own the truck then could he have done it wrong or maybe reused the old o-ring? Cant believe It would leak already.
10-03-2005, 02:22 PM | #17 |
Ok got it from gmcpauls got new lock ring also just incase is this the only place it can leak from? What about the spot were the thing with the wire is no gasket there?
thanks
