Old 10-03-2005, 06:57 PM   #1
skillet
skillet's Avatar
Crankshaft Sprocket Question.
What's a good way to put the crankshaft sprocket on, like with what type of tool and where you get it? Thanks again very much for any info.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter
skillet is offline   Reply With Quote
Old 10-03-2005, 07:13 PM   #2
Vince M
Vince M's Avatar
If you are talking about the timing gear on the crank..I heat it up like on a coffee maker hot plate or a slow cooker and then tap it on with a piece of pipe that fits over the crank. You have to do this quickly while it is hot so get everything ready before hand. It goes on very easily.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 10-03-2005, 08:05 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You live in denton?... you can lay it in the sun for an hour or two and tap it on with the pipe like the guy said above.
I use a propane torch to get it hot if I'm in a hurry though.
