10-03-2005, 09:02 PM | #1 |
My suburban is to low in the front!!!!!!
I bagged the front, 2 1/2 dropped spindles and ART strong arms. Front a-arms lay on the ground and tires hit the inner fenders, but it looks good. However the rearend is stuck up in the air like Joe Dirt's Charger!! Guess I'm going to have to C-notch the rear and add 2 1/2 blocks!! Does anyone know who makes a bolt in C-notch kit for the 67-72 suburbans? I'll try to post pictures tomorrow.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-03-2005, 09:29 PM | #2 |
Bolt in notch wont let it lay all the way out man, if ur gonna do bolt in u wont need blocks
10-03-2005, 09:31 PM | #3 |
I thought I would need the blocks to get the ride height correct. Do you have pictures of yours?
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-03-2005 at 09:32 PM. |
10-03-2005, 09:41 PM | #4 |
10 inch notch with 3 inch blocks in rear, raised front member 1.5 inches 2 1/2" spindles, no lower bag cups
10-03-2005, 09:47 PM | #5 |
Coming as soon as i remove body from frame is new backhalf with traingulated 4 link!!!!! Just trying to get all the welding done on the body before i take it off frame....
10-03-2005, 10:32 PM | #6 |
That 67 hood look awesome with the 72 front clip...
Youth soon passes away, but immaturity can last a life time. |
10-03-2005, 10:35 PM | #7 | |
Happy to be here
10-03-2005, 10:41 PM | #8 |
Bag sits deeper in spring pocket for more drop but the arms are smoth so there isnt any probs with it. IF Customs told me bout that trick
10-05-2005, 09:15 AM | #9 | |
Happy to be here
BTW- Can you look at this and answer how your hood was done- here
10-05-2005, 12:32 PM | #10 |
So it's looking somthin like this :
I used 2.5" blocks in the rear with no notch. It rides pretty close to the bumpstops but does't seem to hit them that I can feel. I do plan to notch it, but just a small one is all it should need. There's on I've seen that has built in upper shock mounts. I'll see if I can find it. Here's what it looks like with the blocks: Also, don't use blocks bigger than 2.5" with stock size wheel/tire combo. The arms are low enough with 2.5" (I can't go through automatic car-washes because the U-bolts/nuts drag the track). Here's a bolt-in from classic performance link Last edited by Frizzle Fry; 10-05-2005 at 12:40 PM. |
10-06-2005, 01:24 AM | #11 |
I finally took some more pics (Frizzle how do you post pics in the body of the text?).
10-06-2005, 01:25 AM | #12 |
New can crusher!! I belive the bumper would go to the ground if it tires weren't hitting the inner fenders (and the lower a-arms touching the ground! ).
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-06-2005 at 01:30 AM. |
10-06-2005, 06:01 AM | #13 |
nice, what bag setup are you using?
10-06-2005, 09:07 AM | #14 |
ARTs bags and arms, ECE spindles.
Rob
10-06-2005, 02:08 PM | #15 |
All Praise RANDY!!
nice Rob, that is some low layin shiznit there....I see you have removed the trim moulding... hopefully I will be able to get that from you in the spring.
Looks good though... what you gonna do for the azz end? |
10-07-2005, 12:36 PM | #16 |
Corn,
No worries on the molding. Probably C-notch and Blocks. Rob
10-28-2005, 08:30 PM | #17 |
Re: My suburban is to low in the front!!!!!!
ECE?? i am looking to get a 67-72 burb, who makes drop parts for them? Ghetocrewzer that thing is going to be badass.. i can't wait to see it done..i would love to have another suburban, or an old one, or an old blazer...
Cut=Custom <<and that is the coolest smiley EVER |
11-20-2005, 08:49 PM | #18 |
PROJECT 7DEUCE
Hey gheto how did you make that hood work????
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-01-2007, 04:14 PM | #19 |
I'M TRUCK CRAZY!
Great pics!
05-02-2007, 03:57 PM | #20 |
ok so you have no lower cup in the front are you still using stock arms? i heard i could do it this way but im afraid of rubbing. i bought a lower plate to sit in the arm.
