![]() Join Date: Apr 2004
I hope this is the right board to ask ?'s on a s-10 Blazer. Anyone out there ever pull the 4.3 from a 93 S-10? The book I have says to get at the top two
Bellhousing bolts that you have to take apart the 4 body mounts in the front and lift the body off from the chassie and block up. ![]()
1968 Chevy 4x4 307 4 speed |
67-72 parts collector,…
![]() Join Date: Nov 2002
I think you can pull the carpet back, (underneath the dash), and use a hole saw to cut a hole in the fire wall. ( then plug it when you are done.)This should allow access to the trans bolts. The other way is to bend the "big lip" or "pinch weld" that runs horizontal across the firewall. This is what gets in the way of your wrench. Either way it's gonna be a b*tch!
Anyone else? Must be someone who has learned a better way. Thanks for the words of encouragement lolife99.
huh ???
I can't help much. I did an engine swap in a baby blazer years ago,but it had a 3" body lift...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
I remove the trans crossmember ,this will let the trans hang down enough to get a long extension to the top 2 bolts...Yes they are tight to get to,Esp. a vortec....Do you need a motor? I have 3 good 4.3 vortec's here,and tons of blazer stuff..I have a complete 93 4dr for parts or just needs a paintjob...Its lexus pearl white...and has a new front clip...Let me know if you need anything... Thanks,Erick
#6 | |
I did the same thing on mine.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
#7 | |
Thanks all. The Blazer has a mint interior and the engine has a spun rod bearing. I plan
on keeping the Blazer so I will not be chopping it up in any way. Thanks for the offer Erick, I have the new crank kit already. I had just replaced the fuel injection, cost 500 just for that part alone so I will not need another 4.3 Vortec motor. That was a 4wd Blazer Erick that you pulled the tranny crossmember out to take out the top two bolts?
Yes just put you a jack under the trans pan,remove the crossmember,then let the jack down,you can get to them with about a 3 foot ext. and while you are there,get that one 9/16 bolt off the rear of the drivers side head that holds the fuel lines on...You will cuss gm if you dont get that one out....
![]() They should have made more room in these things....Thats why i like the older trucks ![]() And you said you replaced the spyder assy. ,When they go bad all the gas goes in the oil pan,then it starves the bearings,when you get it out,you man want to check the cam bearings too...common problem..If you need anything,just holler at me...anything at all...alt,starter,a/c ...ect i have boxes of that stuff...i parted 8 out this year alone...and i have a 92 jimmy 4dr 2wd... ![]() Last edited by bisquik65; 10-09-2005 at 09:43 AM. |
