Old 10-04-2005, 12:25 PM   #1
Yamaha74
Replacing body panels
I have an 83 chevy truck and I was looking at buying the 5pc rocker/cab repair panel kit from JC Whitney. In the description it said that you can weld, rivet or bolt these on. Can you really bolt everything on because I am not a welder. The drivers side is the worst. I need to replace the rocker, cab corner, floor pan and cab supports on the drives side. The passengers side I just need to replace the rocker, cab corner, and I am not sure about the cab supports. The floor is great shape on the passengers side. Are the kits from JC whitney any good? I am open to any and all suggestions.
Yamaha74 is offline   Reply With Quote
Old 10-04-2005, 12:28 PM   #2
a28doc
'87 V20 4x4
a28doc's Avatar
you can bolt em on BUT... it wont look good and worse it will allow water to get behind the metal and rust really quickly welding is the best method to replace body panels for a good look and also to keep rust from reappearing anytime soon
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 10-04-2005, 12:36 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I agree with Doc, for the best results I recommend welding them in. I have heard of people gluing them on, but haven't ever done that.
BTW, I have the 5 piece cab kits that JCWhitney sells only about $10 less.
http://www.73-87chevytrucks.com/merc...tegory_Code=C1
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-04-2005, 12:46 PM   #4
Yamaha74
Cool, I will probably order them from you. What would shipping cost to Johnstown, OH 43031? Do you have your own store?
What exactly does the floor panel consist of? Is it the whole side?
Old 10-04-2005, 09:23 PM   #5
79C10
I'd probably be intested in a set before too long. any idea what shipping would be to 05873. and like said above how big of floor section is it. In the JC Whitney Kit I think its something like 13 inches wide. Thanks for the info.
79C10 is offline   Reply With Quote
Old 10-04-2005, 09:58 PM   #6
82c10
needin' money
how far do they go, mine is rusted a little where it starts the hump for the seat
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 10-05-2005, 12:29 AM   #7
bigarmzz
bigarmzz's Avatar
the new "wave" in installing body panels is to use a special adhesive....i know it sounds crazy, but alot of body shops have started using this method
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 10-05-2005, 11:11 AM   #8
us111
floorpan
you can get the 1/2 pan section that comes with the 5 pc kit and goes from the door over to the support that run's length wise on cab,or you can buy a full floor section that goes from hump to door seperately..
us111 is offline   Reply With Quote
Old 10-05-2005, 12:30 PM   #9
Captkaos
Captkaos's Avatar
The floor sections in my 5 piece kits are 24"W X 33"H. They go from about the front firewall to the seat hump and from the weatherstrip to the trans hump.
They look like this:
Sent PM's to those requesting pricing.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-05-2005, 12:47 PM   #10
Yamaha74
How thick is the metal for the floor pan? It looks thin in the picture.
Old 10-05-2005, 01:22 PM   #11
Captkaos
Captkaos's Avatar
Same as all the major suppliers. 19 gauge. Everything I sell is 19 gauge or higher.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
