Still Green but learning
what to do next, advice?
OK, Oil leak fixed and it turns out the PO probably did do the Rebuild like the seller told me... YEA!!
so whats next. if I go after fixing my radio problem, what is the easiest way into an AC das to check the wiring? from underneith it is a nightmare, should I pull the dash from the top? Or, do I go after the Clutch Hub on the AC compressor? if so anyone know a trick to holding the hub still so you can loosen the nut? Thanks again?
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
only way to access radio wiring is from the bottom/removing a/c duckwork helps as does heater controls and in certain circumstances the glove box liner//tere's no access from the top unless you cut a big hole
#3 | |
Hmmm, maybe a boom box and a DC converter....
