Old 10-04-2005, 03:12 PM   #1
highrpm
Tilt Steering?
Has anyone here installed a 73 up tilt column in a 70-72 truck. Will it work?
highrpm is offline   Reply With Quote
Old 10-04-2005, 03:15 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It can be done, but not worth it.
you'll need to;
rewire the ignition switch
rewire the high beam switch
rewire the wiper switch
cut the lower dash portion for room since the cvolumn is fatter
same with the lower inst panel
No idea if they are long enough.
It can be done, but no reason to do it.
We generally look for 72 - early 82 GM vans with tilts. they are 99% identicle, and are very close to a direct bolt in. See the many threads on the FAQ pages.
Old 10-07-2005, 01:01 AM   #3
72Short_Cut
72Short_Cut's Avatar
I took a tilt column, out of a 1976ish chevy van it fit really well and was the same width. i was able to use the stock hardware and mounts from the stock column. but yes will have to re wire.
1972 Chevy Short Box
Ls1 swap
1977 chevy Chevette
72Short_Cut is offline   Reply With Quote
Old 10-07-2005, 01:07 AM   #4
Longhorn Man
No need to rewire a GM van column, go to the dealer and ask for p/n 1894851. it's an adapter and should be less than 10 bucks.
Old 10-07-2005, 05:48 AM   #5
basketcase
basketcase's Avatar
So that adpater will adapt the column ignition switch harness to the stock under dash harness? What do you do for a shift indicator?
Here it is on Gm Parts Direct
GM PART # 1894851
CATEGORY: All
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $8.67
OUR PRICE: $4.34
DESCRIPTION: HARNESS
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 10-07-2005, 06:16 AM   #6
The adaptor is for non-ignition switch columns.For all the effort,installing a 73-up column will gain a bit of extra security by givivg you locked steering.The pre-81s had dash mount headlight switch and floor mount dimmer.It`s up to you.
Old 10-07-2005, 08:30 AM   #7
Longhorn Man
His only needs the harness adapter... it is out of a van, no ignition switch or anything else to deal with, it is 99$ exactly like the truck ones.
Old 10-07-2005, 03:19 PM   #8
basketcase
basketcase's Avatar
I have a van tilt with the ignition switch but it is starting to look like a lot of rewiring. If I'm going to go that far I also have a 1974 Corvette tilt/telescopic that I might as well use and put in a Lokar floor shift. Or I could put a cool steering wheel on th estock column and call it good enough.
Tom
Old 10-07-2005, 04:21 PM   #9
67chevemall
67chevemall's Avatar
Mine is a 80 trans am. Lots of work but so nice now.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
