Voltage Question
OK you might file this under stupid question but you never know til you ask. My voltage gauge reads approx 15-16 volts at idle and cruise speed...approx 13-14 when lights are on. The needle is fairly steady so I know its got a good connection. Is it too much? I know the alt needs to recharge the battery but at what level...been like that for 3 yrs now. Just thought id see what you "pros" have to say! Thx
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland www.YouTube.com/user/593Films - Watch My Videos! ![]() 1977 Silverado K10 2014 Dodge Durango (Wife-mobile) 2008 Dodge Ram Lone Star Edition (Daily driver) |
Not a stupid question... they dont exist.
As far as I know the normal voltage output on 12 volt systems is 14.4 volts. I know, why do they call it a 12 volt system, still figuring that one out. 14.4V is normal, If its anywhere above 11.5 its good. Just depends on how much crap you decide to plug in. |
its all about the +6 inches
15 to 16 is a bit high... but, nothing to worry about if you aren't blowing out lights and boiling batteries over.
You may want to double check the numbers with a quality digital multimeter... I'm thinking your aftermarket guage may be calibrated a volt high to acomidate the voltage drop found in most cars, and the voltage drop in your rig is a little less than typical. That's my theory. |
I appreciate both of the responses... I guess im ok for now. I am running an Optima red top battery and have a good alternator...nothings getting blown out...YET.thx for the input...
huh?
![]() Join Date: May 2000
I agree with Andy on this one, check the output voltage with a quality multimeter. My voltmeter (VDO) read near 16 all the time, and didn't go down much with the lights on either. I finally checked it with a fluke multimeter, and I was running 14.2 volts while charging, which is totally ok. Sometimes gauges are just off a little.
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
![]() Join Date: Sep 2005
15 volts is normal depending any thing below 13.5 isn't good myt truck charges at 15 16 volts is alittle too high
