wierd question
My truck is lowered with springs in front 3 inch and cheap shocks. When I drive slow and turn I can feel a slight thumping in the floor. Nothing is hitting it and it is not rubbing. Now mind you the floor is just carpet no insulation of any kind. And I know slow truning puts the most strain on the suspention. is it just vibration from the frame and suspension I am feeling? The cab mounts are not that great either. If I move my foot down to flat part of floor there is some insulation and I feel nothing. (as a side note I can feel the bass from my generic speakers in the floor also).
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
sounds like tire is turning to far and you are 'pushing' the tire forward oppesed to turning and thats the sound. ford trucks and jeeps have this problem too.
![]() ![]() Join Date: Jan 2005
One time I lowered a truck of mine by chopping the front springs. The last loop on stock springs is bent so that the end of the spring coil is flat. By chopping the spring, it was no longer flat, so the springs didn't sit straight. When weight would come off the suspension when cornering, the spring coils would clunk against the suspension. I don't know if this is what is happening with your truck, but 3" is a lot to lower just with springs. The springs end up being pretty loose.
