Old 07-05-2002, 05:42 PM   #1
Blue_71
Bloo
Blue_71's Avatar
head problem
had my valve covers off the other day checking everythign out, and i found that the exhaust valve on number six has lost the top lock and the valve stem has wore a hole in the rocker arm.... im defintly going to have to go through this thing when i get some new rings and thinking about a cam swap (considering im swapping heads intake and carb, do it all while im there)
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-05-2002, 06:10 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have seen where the rocker was adjusted too tight and it did this to it. Wiped the lobe off the cam too.
Old 07-05-2002, 08:29 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
When you get the new parts installed bloo, let a pro adjust the rockers. I've talked to you for about the last week, and every day, a few times, you're fiddling with the rockers. Not a good thing to do IMHO.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-05-2002, 09:40 PM   #4
Blue_71
Bloo
Blue_71's Avatar
the only reason ive been fiddling with them is because the last "pro" i had do it didnt do somethign right.. when i had the valve covers off to shine them, i felt of the rockers out of curiousity and every rocker was loose enough that the taps could be hand turned along with the pushrods also.. so i tightened them down the way i was told.. the one with the hole in it was covered with oil on the tip so i never noticed that
1989 Chevy K2500
Old 07-06-2002, 06:08 PM   #5
jlmtrout
Have you tried the locking rocker arm nuts? They are a little pricey,($50 at Jegs, might find a better price by shopping around. Mine came with the cam kit) but they won't come loose. They have an allen head set screw in the center and once you set the valve and tighten the allen screw, they won't back off. Also, you might want to use a vacuum guage when you adjust the valves. If you see the needle start to flutter, the adjustment is too tight, the valve isn't shutting. Good luck and keep on truckin'!-------Jerry
jlmtrout is offline   Reply With Quote
