ignition
Thanks 68 step side.....with your info I got the ignition switch right out !!! Now heres another question. If the key does all of its functions,except turn off the engine, do I need to replace just the switch or both the switch and the tumbler...Thanks again to 68 step side
1970 CST20 |
huh?
![]() Join Date: May 2000
Hey, no problem.
Are you positive the switch is bad? What type of ignition is on the truck? Points or HEI? I wouldn't go buy a new switch until I was 100% positive it was the switch causing the problem, and not the coil wire either A. Touching a 12 volt source, or B. Hooked up to a 12 volt unswitched source by accident. TJ
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
huh?
Hey toolman,
How'd everything work out? Get her fixed? TJ
The bad news is I had to order a new switch.should be here by wed. or thur.. The good news is I got to order a couple of other things I've been wanting.
1970 CST20 |
