10-06-2005, 09:14 AM | #1 |
power brakes
i know this has been asked before but i have an 1971 c-10 i believe it has the 350 in it. right now it has maunal brakes i was wonder how are it would be to install and what i need i can get an booster master cylider and proportioning vavle from advance auto for like 200 buxs. what is involed in installing it? i see on the firewall the 2 upper blots for an booster and the master clyider attached to the bottom 2
10-06-2005, 09:48 AM | #2 |
just need a brake booster - I got mine from a board member for around $20. It installs between your master cyl and the firewall. No new proportioning valve required. Just make sure you get the pedal linkage with the booster and the rod that goes in between the booster and MC. I don't think these are included from Autozone.
Check the FAQs - I'm sure there's info. Overall, this is one of the easiest things you can do for your truck. |
10-06-2005, 10:41 AM | #3 |
YES_____NO
Hey here is a link to help you out. Power brakes
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board Last edited by krue; 10-18-2005 at 01:02 PM. |
10-06-2005, 11:18 AM | #4 |
this is what it looks like cost 116 buxs
10-18-2005, 10:02 AM | #5 |
Re: power brakes
is this all i need? or is there different linkage i need?
10-18-2005, 10:29 AM | #6 |
chevy truck fan
Re: power brakes
truckdude 219,
i am interested in the same thing! were did you find the picture?? i will probably buy the same as you.. thanks!! rodstored-72 |
10-18-2005, 10:30 AM | #7 |
Re: power brakes
you will need the mounting bracket and hardware to the firewall and a different rod that attaches to the brake pedal. hopefully someone can post a pic. for you.
71 C10 SWB BLACK AND WHITE 350 CRATE TH350 ENJOY LIFE |
10-18-2005, 11:40 AM | #8 |
Re: power brakes
The link to the power brakes does not work, is anyone else having trouble accessing the tech tips as well, or is it just me?
10-18-2005, 12:17 PM | #9 |
Re: power brakes
i find that at www.partsamerica.com or you can go to advance auto parts can some post an picture of the rod i need please????
10-18-2005, 01:02 PM | #10 |
Designated A-hole!
Re: power brakes
Mongo's link should work now.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-18-2005, 01:24 PM | #11 |
Re: power brakes
To make matters even more confusing:
I have one of these in my garage: http://cgi.ebay.com/ebaymotors/ws/eB...tem=7994745616 Can't say how it works, but should be interesting. I would suggest getting it from someone else though, FatRodder took too long and had seriously crappy customer service. Supposedly, the dual diaphragm small booster puts out more force. |
10-18-2005, 10:04 PM | #12 |
Re: power brakes
I recently added a dual diaphragm booster off an 86 IROC Camaro but had to lengthen the rod by using another truck rod and adding it to the Camaro rod. I slipped a piece of tubing over the rod ends before welding to help strengthen the rod. I also had to re-drill the hole for the bolt on the pedal to keep the angle of the rod right. It works great, my wife drove it down our driveway and said she like to have slung herself througth the windshield . I told her it's touchy! below is a pic of my set up.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! |
10-19-2005, 07:14 AM | #13 |
Watch out for your cornhole !
Re: power brakes
Here are pictures I took last time I swapped a truck to power brakes. You can see that there are two brackets and a linkage piece in the middle of them. You'll need all of that to do the install.
By the way, around here, a rebuilt power booster runs about 75 bucks at the parts store. With the booster, brackets pictured above, and a length of 3/8 hose and fitting for the intake, it will take under an hour to do the duty.
10-19-2005, 08:15 AM | #14 |
Designated A-hole!
Re: power brakes
Yeah for the money and time spent it's the best upgrade you can do to your truck imo.
