10-06-2005, 11:01 AM | #1 |
Lowering w/ torsion bars?
I want to drop my 60 Apache 3" or so. It is equipped with torsion bar front suspension. Can I lower it with torsion adjustment alone, and is this a good way to lower it? Thanks!
'66 C10 Longbed Stepside, 350, 4-speed |
10-06-2005, 11:20 AM | #2 |
I got a pretty good front drop doing it on my '61 about ten years ago. Had a nice slight rake with 2.5" lowering blocks in the rear. Just don't back them off too far
10-07-2005, 11:52 PM | #3 | |
Here's my '60 Burb that I lowered. |
10-12-2005, 04:39 PM | #4 |
1962 C-10
You can do it that way. Didn't I tell you! Poorboy style........Loser.... I got your back on this....
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
10-12-2005, 05:44 PM | #5 |
C10 now is a GMC
I lowered the front on my '62. Before you start to lower the frontend, make sure that the frontend(wheels) is off the ground, so that the pressure is off the torsion bars, and make sure the threads have been soaked good in penitrating fluid. Then proceed to turn the 2 bolts counter clockwise(to the left) to lower the frontend.
I got the front on mint aout 5-6 inches in front, and in the rear I got 2 inch lowering blocks, and the coils are 2 inches shorter. From the side view of my truck, the front is lower than the back giving it a nice rake. Pic David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
04-17-2012, 07:06 AM | #6 |
Re: Lowering w/ torsion bars?
Ive got a 63 gmc shortbox with torsion bars I'm lowering, could really use your advice, get ahold of me Brian
Posted via Mobile Device |
04-18-2012, 09:37 AM | #7 |
It's not the "right" way to do it, but lowering it won't hurt them. May soften the ride some, but use stiffer shocks. You just don't want to lift a truck like that, no more than an inch or so. This puts too much tension on the bars, fatigues them, and they could break....
Ditto on the comment about the front wheels being off the ground!!!!
1960 C-10 2000 Dakota R/T 1966 Fury I 2dr post 1984 Big Bronco 2002 Durango SLT (Bride's Ride) |
04-18-2012, 10:26 AM | #8 |
Has anybody put 2.5 lowering spindles with drum brakes and then adjusted the bars? Or do you have to change to a dis brake setup? I am planning on lowering my 62 in the future and want some ideas.
04-18-2012, 10:35 PM | #9 |
I have never seen of drop spindles for drums. I don't think any body makes them. Why would you? Then you couldn't make people buy the disk brake kit.
04-19-2012, 12:37 AM | #10 |
When I bought my truck the previous owner had lowered it nicely w/ the torsion bars. Since I wanted to upgrade to discs anyway, I went ahead and got the 2.5" drop spindles. Then I backed off on the t.b. somewhat. I don't think you can get a drop kit and keep the drums.
When was the last time you did something for the first time? We never really grow up, we only learn how to act in public. |
04-19-2012, 12:41 AM | #11 |
But Found Her 25yrs Later!
some additional threads:
http://67-72chevytrucks.com/vboard/s...torsion&page=2 http://67-72chevytrucks.com/vboard/s...hlight=torsion http://67-72chevytrucks.com/vboard/s...hlight=torsion
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
