Old 10-06-2005, 03:13 PM   #1
Larry68GMC
WTB: SB 400 and rear end
Just got back from Iraq and looking for a complete SB 400, would be interested in just the long block as well, within a few hours of Oklahoma City. Also a 3:73 or 4:10 5 lug posi with leafs...Thanks...Larry
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1
RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall
'05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD
Larry68GMC is offline   Reply With Quote
Old 10-06-2005, 03:30 PM   #2
Jakes-66-K10
Jakes-66-K10's Avatar
How much you looking to spend? I have a built one with vortec heads with intake manifold I was going to use on my '66... but it's just sitting around doing nothing for about 6 weeks now.
Jakes-66-K10 is offline   Reply With Quote
Old 10-06-2005, 03:35 PM   #3
cst70rocket
Larry, there is a guy in Wichita Falls,Tx with a stock 400 short block, never been torn down, standard bore. He is asking $300 for it and you pick it up. Very nice guy. I just bought the rotating assy from him. His name is Scott Schultz, his number is 940-631-5865 You can tell him that Kirk from San Angelo sent ya.
Kirk
cst70rocket is offline   Reply With Quote
Old 10-06-2005, 03:38 PM   #4
cst70rocket
I may also have a buddy with a later model 10 bolt with fresh posi,new 3.73 gears and new brakes/drums if he still has it, he was asking $500 for it. It's leaf sprung, and I believe it's a bolt in, but don't quote me on that. If interested, email me.
cst70rocket@yahoo.com
Kirk
Old 10-07-2005, 11:20 AM   #5
Larry68GMC
Thanks for the info cst70, How much you asking and what are the specs Vortex? Thanks...guys
Old 10-07-2005, 12:47 PM   #6
Jakes-66-K10
Larry, it was just built about 6 or 7 weeks ago. Bored .020 with dished pistons, stock crank, 5.7 rods, Comp Cams XE274, Vortec heads. Heads are bolted on, but I was planning on taking them off and machining in more lift for this cam. It's all complete with balancer and flexplate (both balanced for the 400) and an Edelbrock RPM intake. I'd sell it for $2k, also have a new TH400 short shaft tranny built to handle this motor and an oversized aluminum driveshaft - probably like $2600 for the entire drivetrain. If that's too steep no worries, my 66 keeps grinning at me knowing what it'll have thrown into it someday.
Old 10-12-2005, 09:26 PM   #7
gmchevy
s-10 v8 (400/350)
Hi Larry, I have a 88 s-10 blazer (daily driver) with a 400 small block...30 over, mild cam, edelbrock carb/manifold. $1500.00 if interested. I'm in Wichita Kansas.
68 GMC shortbed
72 Chevy K5 Blazer CST
72 Chevy half ton 4X4
72 Chevy swb 4x4
gmchevy is offline   Reply With Quote
Old 10-12-2005, 11:32 PM   #8
69Goody
69Goody's Avatar
Hey Larry...Sounds like a good combo. That's pretty much what I have under my 69 GMC. A stout 400 bored .030, Edelbrock RPM heads, airgap manifold, crane gold rockers (1.6) motivated by a solid cam and connected to a posi 3.73 with new Moser axles. 5 on 5's all around compliments of a 78 doner. The only thing I'd do differently is stay away from the solid cam. Sounds good when valve train stays in place...go hydraulic.
Good luck and welcom back!
Only the Mediocre are always at their best...
'69 GMC LWB 406, TH400, 3.73 Posi'
Things I've learned from my truck...If I was an automaker, my vehicles would be overpriced, run rough, and get 5MPG.
69Goody is offline   Reply With Quote
Old 10-14-2005, 12:59 AM   #9
Larry68GMC
gmchevy, you got a PM about the blazer..thanks
Old 10-20-2005, 05:55 PM   #10
Larry68GMC
Re: WTB: SB 400 and rear end
Still looking for this stuff. Did you get my message gmchevy? Thanks...
Old 10-20-2005, 06:38 PM   #11
David Johnson
David Johnson's Avatar
Larry,
I have a 4 bolt 400 (hard to find), crank and balancer. I'm just down the road in Tecumseh. $500
David Johnson is offline   Reply With Quote
Old 10-20-2005, 07:48 PM   #12
RicksTrucks
RicksTrucks's Avatar
I am picking up a 70 LWB tomorrow with a BB 400, may end up parting it out. It is all there: power steering and A/C with all of the brackets.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 10-21-2005, 09:37 AM   #13
Larry68GMC
David and Rick, can you guys get some pics and casting numbers? How much you wanting for the BB 400 and all the brackets, motor mounts, etc Rick? Thanks...Larry
