10-06-2005, 03:42 PM | #1 |
Door not Stopping
My driver side door opens up so far that its hitting the front left fender. What is the fix?
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
10-06-2005, 03:44 PM | #2 |
More Cowbell....
Get a good bungie-cord!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
10-06-2005, 03:55 PM | #3 |
There's supposed to be a "stopper bar thingy" (yes, that's a technical term) on the top door hinge, take a peek at your passenger side door. You may need to replace your door hinge, as I'm not sure if you can buy the "stopper bar thingy" seperatley
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-06-2005, 04:31 PM | #4 |
Cantankerous Geezer
You have to replace the hinge, the stop is integral.
Fred There is no such thing as too much cam...just not enough engine. |
10-06-2005, 05:04 PM | #5 |
You can actually replace the hinge stop without removing the hinge. If you have an old hinge with a good stop and you can fit your hand inside the door, you can:
1. drive out the roll pin 2. remove the metal stop piece from inside the door and 3. remove the little hard vinyl like pads. Install in the reverse order. I replaced both of mine in this way. Hope this helps. Last edited by demi; 10-06-2005 at 05:05 PM. |
10-06-2005, 05:44 PM | #6 |
Thanks Demi
10-06-2005, 06:42 PM | #7 |
install a door stop on your fender to protect it in the mean time, you may have to drill a pilot hole to get the screw started first tho.
10-06-2005, 09:03 PM | #8 |
Better late than never
That is a great "how to" demi. I need to do this because my doors don't stay open when a park on even the slightest upgrade.
This post should go in the FAQ section.
1970 C/10 SWB Stepside |
