Old 10-06-2005, 04:52 PM   #1
tattoo
"Bondo, just say no!"
tattoo's Avatar
lwb to swb chop?
Does any one know how many inches im going to cut off my lwb to make it a short box and what length my new driveshaft is going to have to be? any help here would be greatly appreciated.
tattoo is offline   Reply With Quote
Old 10-06-2005, 06:18 PM   #2
djracer
djracer's Avatar
too bad you are so far away I have 3 short frames!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-06-2005, 06:31 PM   #3
lpaine
lpaine's Avatar
Look in the faq submissions page 3 by glock35ipsc; excellent thread with good pics, I'm going to be referring to this a lot when I get started on shortening my '72 to a s.w.b.-if I can ever find the time that is.......
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 10-06-2005, 07:09 PM   #4
Maximum Overdrive
December 21, 2012
The April 2003 issue of Custom Classic Trucks they did a article on shortening a 67-72 truck from longbox to shortbox. (Pages 30-35) They cut 8 inches off the back of the frame and then 12 inches was taken out of the frame under the cab area and it was then reinforced and welded back up.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 10-06-2005, 08:42 PM   #5
tattoo
tattoo's Avatar
i think i'll just sell the long frame and buy short i found one around town for 350cdn it needs a little lovin but with new cab mount its about the same cond i got now. can i use my old cab mounts? I dont like the idea of cutting my chevys spine
Old 10-07-2005, 09:48 PM   #6
Maximum Overdrive
December 21, 2012
Its possible to use the old cab mounts depending on the condition they are in but is wise to just replace them if they are old and broken down. If you want the article PM your address to me and I will photo copy the article from CCT and send it up to you.
Old 10-08-2005, 09:24 AM   #7
72MARIO
72MARIO's Avatar
I am in Uxbridge. Just south of you. Do you know a guy up there Name Terry ?
I cut my frame down 12" from under the cab and 6" off the back. I took 8" off but I would like there to be more under the rear sill of ther box.
Now that it's done I dont even think it was a long box I tend to forget.
Here is a pic of the finished truck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 10-08-2005, 11:46 AM   #8
tattoo
tattoo's Avatar
thanx for the info , sweet ride! like your mirrors. I do know terry me and him swap parts all the time. small world.
Old 10-08-2005, 11:47 AM   #9
tattoo
tattoo's Avatar
how did your gas tank relocate go? got any pics, wheres your filler.
Old 10-08-2005, 11:49 AM   #10
FormerMember
Heh, I have 2 SWB frames for sale.
One that's been blasted and treated with a 4/6 drop installed with new kunckles, stainess brake lines and hoses and aluminum fuel line.
FormerMember is offline   Reply With Quote
Old 10-08-2005, 11:54 AM   #11
tattoo
tattoo's Avatar
now your just teasing, how can you get those frames here and how much?
Old 10-08-2005, 12:08 PM   #12
FormerMember
Shipping can be easily accomplished by Amtrak rail. They will handle up to 1500lbs.
Or you could drive
I am no tease BTW. I was building this until I found another vehicle that's in slightly more together.
I have a cab sitting in primer, another cab that needs love, two very solid short bed frames, 2 very good SWB fleetsides, a 402 BBC (both frames are BBC btw), a th400, 2 very solid doors, a 67 front clip, a 71 front clip. We could put a truck together in about 4 hours that would tow the rest back
Old 10-08-2005, 01:12 PM   #13
Frizzle Fry
Frizzle Fry's Avatar
For anyone interested. Here's a frame chop article.
I plan to do it to my Suburban when the '61 is done. Less work than a frame swap IMO.
Frizzle Fry is offline   Reply With Quote
Old 10-08-2005, 06:47 PM   #14
Maximum Overdrive
December 21, 2012
That is the same article that was in Custom Classic Trucks.
Old 10-09-2005, 11:12 AM   #15
tattoo
tattoo's Avatar
what would you do in my situation, working on my lwb buy the other swb frame for 300 or chop my lwb, i dont plan on selling the truck so value is not an issue. there both roughly the same condition rolling chassis both need brake and line work. help me figure out my thankgiving weekend .
Old 10-09-2005, 11:36 AM   #16
cableguy0
just get the swb frame. unless you are a good welder modding the lwb frame could possible be unsafe. its a ton easier to start with one that you know is right rather than cutting welding measuring a million times etc
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-09-2005, 11:38 AM   #17
72MARIO
72MARIO's Avatar
I would like to see the frames But the short frame would get the project going faster. Are they rolling ? $300 is not too bad.
I have a 20 gal fuel cell. Filled thru a stainless filler in the bed floor. I have a ECE rear crossmember.
I have removed the mirriors from my truck now all they are is Peep mirrors.. They were totally useless. I guess the name should have told me that.
2005 TAHOE DD
Old 10-09-2005, 11:41 AM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by cableguy0
just get the swb frame. unless you are a good welder....
Ther's your answer. If you have good fab skills and can weld properly mod your LWB frame. If your average Joe hotrodder with minimium or no welding skills swap frames.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-09-2005, 12:17 PM   #19
tattoo
tattoo's Avatar
thanx for all the help, i'll pickup my new chassis tonight if i have time. I think i'll save the cutting for the pros. anyone need a lwb frame?lol
