Old 10-07-2005, 12:23 PM   #1
cheyenne10
cheyenne10's Avatar
dropped spindle questions
Who has links to good posts on dropped spindles. Brand comments, fit comments, turning radius issues, etc. Without search its tough.
Bob
cheyenne10 is offline   Reply With Quote
Old 10-07-2005, 05:23 PM   #2
wannabeburbowner
wannabeburbowner's Avatar
Not to hi-jack your thread, but I am also wanting to know what all I need to change to put a 73 and up spindle on my 71 C10. I got some from Summit Racings scratch and dent sale for $100....I couldn't pass them up. Do I just have to change the balljoints?? The the disc brake rotors and calipers the same??
Thanks,
Travis
71 Chevy Long Bed (gettin' bagged)
84 GMC K1500 (Sold)
85 Monte Carlo SS white w/gray int. (being a dumba** and totaled it )
85 Monte Carlo SS clone T-top (Sold)
72 Chevelle-tubbed
64 Buick Sportwagon
wannabeburbowner is offline   Reply With Quote
Old 10-08-2005, 04:29 AM   #3
70chevc10
70chevc10's Avatar
check the FAQ section, i know this has been asked a lot in the past
70chevc10 is offline   Reply With Quote
Old 10-08-2005, 02:43 PM   #4
cheyenne10
cheyenne10's Avatar
Faq
I checked there and did not find the discussion I need. I was looking for content or pros and cons to ECE, Mcgaughys, CPP, or other dropped spindles. Seems like there has been some preference or differences due to standard tie rods end acceptabliity and turning radius when complete, etc.
Bob
Old 10-08-2005, 03:13 PM   #5
70short/step
70short/step's Avatar
I used and highly recommend ECE dropped spindles. I used the kit on my 70 to drop and add disc brakes. They are of the highest quality and include all parts needed to do the swap, less brake fluid and grease. I couldnt be happier with their parts a and their service. Call them up and talk to them.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 10-08-2005, 05:58 PM   #6
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Can't go wrong with McGaughy's or ECE. I've got McGaughy's components on both my '03 and my '67 and they are quality parts.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-09-2005, 06:21 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've used Western, BellTech, Ground Force, and ECE spindles in my life. Never had a problem with any of them.
I prefer ECE for early trucks and BellTech for later models. ECE is top notch stuff and support people too. Call them, they usually offer them for cheaper than advertised price if you call and ask when you order.
Wannabe...
On your truck, the 73 and newer spindles require 73 and newer upper ball joints and outer tie rod ends. On your 71, the later model tie rod end will screw into your adjuster sleeve without any fancy adapters needed like the earlier trucks require. The upper ball joint installs directly into your control arms. The lower ball joint is the same on 71 through 87 trucks, so no changing required. After swapping the upper B/Js and outer tie rod ends, the brake parts off your 71 spindles will swap directly onto the newer dropped spindles..
