Old 10-07-2005, 12:40 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
8.1 Vortec ?????
How difficult would it be to put in a 8.1 with Allison. I dont really mean the easy things like mounts, exhaust, etc more like the electronics part. If the motor has all the wiring with it could you literally just hook those up and stuff them inside the cab or do they need to tie into the factory dash gauges etc. Also the Allison, what does it need.
I am sure this has been done
Thanks for your input
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 10-07-2005, 01:36 PM   #2
cableguy0
the allison is fully computer controlled. most of the newer computer systems have different sensors for the gauge and then another for the computer to get its readings from. i know sure on that specific engine but for the most part thats how it is.quite a few guys here have done the ls1 swap and the electronics will be basically the same between those and the 8.1 motor
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-07-2005, 07:33 PM   #3
dwaite72lnghrn
I am pretty sure the engine is drive by wire so you would need to rig up the gas pedal to a sensor and run the wire to the computer then the computer tells the engine what to do. You would have to make a larger hump for the allison as it is higher further back than the th400. But anything is possible with time and money. The intake should fit in with no extra pounding. The only issue then is the fan setup for the radiator, the stock mounts don't leave enough room for the mechanical fan setup so you will have to convert to all electric. Without air it would be easy with pushers, With air you are going to have to get creative.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 10-07-2005, 08:50 PM   #4
shifty
Questionable
shifty's Avatar
I would post at the LS1tech.com forums and ask or just PM HartRob and ask him. I'm pretty sure you can convert most of the drive by wire systems over to a standard pedal-and-wire setup using brackets from earlier model Vortec engines. I remember seeing HartRob say something about this in one of his posts recently.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
