reset odometer
How do I reset the odometer on my 71 cheyenne to 0. Thanks.
![]() ![]() Join Date: Jan 2005
There is an FAQ for this, what I had to do was take the speedometer apart and remove the rolling numbers assembly. Carefully remove the plastic guide on the metal pins. Then starting from the left put it on zero and work your way across from left to right. When you hit zero on one roll, be sure to hold the metal pins with your fingers as you work your way across. Once it has been reset, put the plastic guide over the pins and re-assemble.
