07-06-2002, 03:18 AM | #1 |
Switching to HEI...wiring question
350 in a 68 Chevy SWB. Have a points distributor in there now...going to switch to HEI soon. Question is...do I have to run a hot wire straight from the fuse box to the new HEI coil? or can I make a new connection out of existing wire that plugs on to the - side of the old external coil from the wiring harness? Now this wiring harness that is on there now is only about 2 months old, bought it from Rick's. Also what gauge should the wire be?
Thanks again! |
07-06-2002, 07:30 AM | #2 |
its all about the +6 inches
The wire in your harness is not a full 12 volts. The new HEI needs 12 volts. Just run a wire from the ING UNFUSED location and plug it into the new distributor.
07-06-2002, 08:32 AM | #3 |
Put a 5 amp inline fuse in that new wire also.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
07-06-2002, 09:27 AM | #4 |
Shortbox wanna-be.
Yup, I second that. You cannot use the stock wire, as it is a resistance wire. You must run a new 12 guage wire directly to your fuse box.
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) |
07-06-2002, 10:31 AM | #5 |
