10-08-2005, 11:36 AM | #1 |
carb question
I have a holly 3310 seams to be leaking a little fuel from the throttle assembly drips onto intake. Any ideas or is this common. (no much leakage)
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
10-08-2005, 12:07 PM | #2 |
DON'T TREAD ON ME
If your air bleeds get stopped up it can cause this to happen. If that's the case you'll have to rebuild the carb or at least blow out the air bleed holes. Of course I could be wrong but what ever it is a rebuild will most likely cure the problem.
Old Yeller |
