help
changing oring on fuel sender the tab on the oring does it go in any speacial way?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
sender still leaking for like 5 minutes after fill up looks like it is leaking from the fuel line were it goes thru the sender?
It sounds like the solder joint is leaking. If you remove the sender and clean all the gasoline off of it they can be resoldered fairly easy.
Jim |
what is the solder joint? is the fuel line supposed to move?
Fuel line shouild not move, sounds like the solder joint, where the fuel line goes through the plate that goes onto the fuel tanks has gone bad. This would account for your other trouble of the float banging against the tank. You would need to clean the fuel residue off and resolder the joint. I am not sure what type of solder is in the joint now, but I would imagine it is a silver solder, or perhaps a silicon bronze brazing rod may do the trick.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
