Old 10-09-2005, 12:22 AM   #1
shifty
Questionable
shifty's Avatar
Is there a tool to put a pitman arm on?
I'm trying to rebuild my steering and swap to power steering. It's all torn down, wire brushed out and repainted and I got all the new parts (Moog/TRW) for around $135.
Trying to get my pitman arm back onto my new PS gearbox, but the damned thing does NOT want to go on (think it's the paint or powder coat on the box making it stubborn). I need something that will press the pitman arm back on. Is there such a tool? Is there a tool to get the center link onto the idler/pitman arm?
Anyone got any tips otherwise about putting all this crap back together?
Right now I've got the idler arm support and idler arm on loosely, PS gearbox is mounted, trying to get the pitman arm on so I can bolt up the centerlink, then attach the tie rods. Any advice is appreciated.
Took lots of pics for a writeup so far.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-09-2005, 01:28 AM   #2
4x4Poet
On our stock steering boxes, the pitman arm spline engagement is tapered. Should slip on at least 1/4 way before tapping it on further. My last install went on near all the way. In any case, clean the splines, male & female, then force something like a big screwdriver inbetween the split in the pitman arm to open it just a little to get it on.
But I've found that when I couldn't get the pitman arm back on right off, it was because I had not properly lined up the splines on the shaft and pitman arm to include the non-splined portions. So, if you're as mechanically inclined as I am, make sure you have perfect spline alignment before using a BFH.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 10-09-2005, 01:29 AM   #3
cableguy0
clean the splines up and get all the paint off. normally i run the nut on with an impact gun to make sure its tight enough and fully seated.there isnt any tool to put it back on. impact gun and a socket is the only way i have ever done it. i wouldnt trust getting it tight enough by hand
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-09-2005, 02:53 PM   #4
BubbaGreen
Pitman arm install
You HAVE to get ALL the paint out of the splines on the pitman arm, its an extremely close tolerance part....if you had the part powder coated, your gonna have to have patience....tape off the entire outsides part. then get some DAD's paint remover and brush it in the spline area very carefully and let it sit for about 30 min. Flush this out with hot water and use a metal parts brush and clean the splines good. then go back over the remain splines with a scribe tool to get them good and clean.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 10-09-2005, 04:09 PM   #5
hgs_notes
GEARHEAD
hgs_notes's Avatar
Actually, I think you need a pitman arm from a power steering box. They are different sizes, you can't use the old one.
HG
hgs_notes is offline   Reply With Quote
Old 10-09-2005, 10:51 PM   #6
4x4Poet
Originally Posted by hgs_notes
Actually, I think you need a pitman arm from a power steering box. They are different sizes, you can't use the old one...
Haha! That would up this thread's entertainment factor...
Old 10-11-2005, 01:14 PM   #7
shifty
Questionable
shifty's Avatar
I have a new pitman arm already, thx If anyone wants to pick up a manual gearbox and pitman arm, PM me. Ive got one for sale.
I think the problem is the paint as described, but possibly the problem is in the spline alignment. I noted the splines when attaching. Everything appears to be tight tolerance - pitman arm don't wanna go on the PS gearbox, idler and pitman won't go on the freshly painted center link (they all go on part way) and I haven't tried the tie rods, I was out of town all weekend. In Washington DC this weekend, so I'm trying to do more work on Wednesday. Had to remove and sell my tank to another board member last night.
Thanks for the tips guys, I know they will help.
Oh - and cableguy - For the record, some of those steering parts came in a TRW box but a couple of them had MOOG caps on the grease seal area and one or two were stamped with the "problem solver" thing that MOOG uses, so I'm thinking MOOG and TRW are officially the same company now.
Old 10-11-2005, 01:16 PM   #8
cableguy0
yea it looks that way. shoulda said something im 35-40 minutes away from dc
Old 10-11-2005, 01:41 PM   #9
shifty
Questionable
shifty's Avatar
We've got a pretty packed weekend. I have quite a few friends up your way, probably gonna be up there again in the next 6-8 months, I'll give a shout in advance next time.
Old 10-11-2005, 06:15 PM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
It should not have paint on the splines. Also, the arm can only go on four ways, due to the splines. Last one I did was tight, so I lubed the splines with anti-sieze and jacked up the front of the truck to where the arm was somewhat parallel to the floor. Then I put a bottle jack under the arm and slipped it on.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-12-2005, 10:50 AM   #11
shifty
Questionable
shifty's Avatar
There is paint on the splines. It came from the store like this (rebuilt, repainted)
