Old 10-09-2005, 12:24 PM   #1
blazekraze
pulls to the right
what would cause this, It pulls to the right while driving, the faster I go , the more it pulls. Whe the brakes are applied it straightens out. I don't think it's the brakes, could it have something to do with the alignment? or is it a suspension issue.. This is on a 99 GMC Safari van. thanks..
blazekraze is offline   Reply With Quote
Old 10-09-2005, 12:28 PM   #2
hobbz
hobbz's Avatar
sounds like it is out of alignment
Hobbz-Garage
1987 Short Step 350/350
hobbz is offline   Reply With Quote
Old 10-09-2005, 12:45 PM   #3
blazekraze
If it's the alignment, what would it take to throw it off? This the wifes' kid hauler and I took it out for a little bit yesterday and noticed the problem. She says it's been like this for a couple of weeks but she thought it was her imagination.
Old 10-10-2005, 01:08 AM   #4
hobbz
hobbz's Avatar
were the tie rod ends replaced recently? is so and it wasn't aligned afterwards that would be your prob. otherwise you might want to check the tie rod ends or something in that area
Hobbz-Garage
Old 10-10-2005, 01:50 AM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
I had this problem on my 92 1500 and it turned out to be a brake hose. it was colapsed where the mounting bracket clamps around it and would not let the caliper release with the other side. I had replaced everything but the hoses with no luck and then tried to blow thru the hose, no go even with compressed air. Replaced the hoses and no more problem.
It could also be a badly worn wheel bearing.
dwcsr is offline   Reply With Quote
