10-09-2005, 03:37 PM | #1 |
Help with a/c..
Any ideas how the a/c compressor will mount with the setup I have below? I'm assuming I can move the alternator to the other side with a mount of some sort but I'm not sure how I will be able to mount the compressor. Is there a bracket or something I'm missing that I will need? Thanks
1971 Chevy swb Chevy trucks and import cars |
10-09-2005, 03:59 PM | #2 |
Watch out for your cornhole !
You have a long water pump bracket and pulley setup. You need to convert to short pump setup to be factory correct.
10-09-2005, 09:26 PM | #3 |
Of course I should have known it wouldn't be that easy Is there a specific type water pump asembly/bracket that I need? Are all the short assemblies the same or do I need one specifically for a/c? Alot of questions I know
10-09-2005, 09:38 PM | #4 |
short water pump is all you need. i believe the alternator goes on the other side, and the compressor goes on the pass side. I haven’t figured out my brackets yet because the guy had headers and a custom bracket for the alternator as well as a tractor pulley on it, and no ac for me to start with.
10-09-2005, 09:43 PM | #5 | |
10-09-2005, 09:49 PM | #6 | |
you could mount the compressor foward some with custom brackets and keep the long water pump and the pulleys. |
10-09-2005, 09:55 PM | #7 | |
10-09-2005, 09:57 PM | #8 | |
or
10-09-2005, 10:01 PM | #9 |
lol...well then wht do you mean by mounting it forward? On the same side as the Alternator?
10-09-2005, 10:41 PM | #10 | |
10-09-2005, 11:31 PM | #11 |
ok long water pumps extend towards the front more than a short water pump, so they're longer. by mounting the compressor foward with longer brackets, you can keep your long water pump and all the pulleys in place. you save yourself from buying new pulleys that are designed to be closer to the engine with a short water pump.
10-09-2005, 11:51 PM | #12 |
Or you can purchase a serpentine set-up. I just got one, and in process of installing it, sweet setup with the alt and ac on the correct sides.
10-10-2005, 12:18 AM | #13 | |
72 Jimmy custom 72 Sub CST 79 2 ton Camper |
10-14-2005, 12:23 AM | #14 |
Saving one 72 at a time!!
I have all those old small block brackets as well, If I remember correctly there is also a custom bracket/spacer that makes it possible to bolt the bottom bracket to the heads through your headers..... Again if I remember right, I bought it from O'reilly in the Mr. Gasket section... it was a pretty standard spacer/bracket.
