10-09-2005, 05:44 PM | #1 |
question about split rims
i have a 69 chevy tow truck with split rims on them . i want to swap them to regular rims but cant find any that will fit 3/4 ton wheels will fit the front i havent tried the rear but i need something like a dualie wheel any ideas?
IT'S HARD TO MAKE CHICKEN SALAD WHEN YOUR USING CHICKEN S......... 1968 crew cab build (under construction) |
10-09-2005, 05:54 PM | #2 |
Watch out for your cornhole !
Simply use later model non split wheels.
10-09-2005, 06:15 PM | #3 |
20' Daredevil (Ret)
What he said - look for any newer 1 ton with duals (except Ford - they may have the metric bolt pattern).
10-09-2005, 08:16 PM | #4 | |
OH & 3/4 TON WHEELS WILL NOT WORK ON A 1 TON DUALLY
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
10-10-2005, 07:40 AM | #5 |
I machined chamfers into my chrome Budds and use beveled lug nuts on the stock studs,no problems.The hub fits and carries the weight.I wanted to go to the 9/16 studs and the old fart machinist talked me out of it because he had done the same on his car hauler with success.I still like Junkyard`s way best.
10-10-2005, 12:07 PM | #6 |
THESE LUGS PROVIDE QUITE A LARGE AMOUNT OF PIECE OF MIND. ESPESIALLY WHEN TOWING 10,000 UP & OVER THESE MOUNTAINS. THE OLD 1/2" STUDS WERE CONSTANTLY COMMING LOOSE EVERY 250 MILES OR SO. I HAVEN'T BEEN ABLE TO TIGHTEN THESE UP ANY AT ALL IN OVER 15,000 MILES. DUEL WHEEL TRUCKS WERE (& ARE) DESIGNED TO USE FLAT, NON-ANGLED LUG NUTS WITH AS MUCH SURFACE AREA AS POSSIBLE. IT'S HAIRY ENOUGH TOWING VERY HEAVY VEHICALS WITHOUT WORRYING ABOUT JERRY-RIGGED LUGNUTS. THERE ARE AN AWFUL LOT OF INNOCENT SOCCER MOMS IN MINI VANS OUT THERE ON THE ROAD, & HERE I COME BARRELING DOWN THE ROAD, DOING 50 OR 60 IN A 36 YEAR OLD 6500 LB TRUCK TOWING A VEHICAL WEIGHING BETWEEN 4,000 & 10,000 LBS. I'D HATE TO WIPE ONE OUT. PIECE OF MIND IS A WONDERFUL THING. SEEMS LIKE THE OLDER I GET... THE MORE IMPORTANT IT IS TO ME. GO FIGURE. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 10-10-2005 at 12:19 PM. |
