![]() Join Date: Sep 2001
off topic - need quick help on Camaro
Having trouble with '89 Camaro w/ 305. We've got power to the coil, power from coil to distributer, but no spark. Plugs and wires look ok. We've replaced the cap, rotor, coil, and ignition control module. And the rotor is turning fine. Also, we've got 12 volts coming out of coil when ignition is in Run, and about 10 when the starter is turning.
plenty of fuel too. Any ideas? Last edited by N2TRUX; 10-09-2005 at 08:38 PM. |
Where's my beer?
The first thing you need to do is spell Camaro right. Sorry just sort of a pet peeve as a former Camaro owner. Also, sorry I'm not sure what is the problem with yours. Mine was an 81 so pretty different from yours.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Parts and more parts
Did you change out the pickup coil inside the distributor? Thats the little round thing at the bottom of the unit that the shaft goes through. I have had one of those go out before and it had to be replaced.
Still drivin' a Rat Rod
Make sure there aren't any wires inside the dizzy shorting out to the base
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website Last edited by Brainchild; 10-09-2005 at 08:04 PM. |
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
TBI or TPI?
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
#6 | |
Happy to be here
![]() Join Date: Mar 2000
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-10-2005 at 10:46 AM. |
Sorry about the spelling there - my spellings not that great as it is and the faster I type the worse it gets! That pickup coil is the one thing we haven't replaced - I will check in to that. Does the dist have to be pulled out to replace it?
I'm not sure if it's TBI or TPI because I don't know the difference - it's the injection that looks like a carberator. And you can see the jets spraying gas in so I know it has fuel. |
#8 | |
Yes that sounds like a TBI
Not sure it'll store any codes,but it's easy to check and see.You might get lucky and the car will tell you what's wrong ![]() http://www.troublecodes.net/GM/
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website Last edited by Brainchild; 10-09-2005 at 11:51 PM. |
blood type; Retumbo
your throttle body injection is spraying fuel so the ECM is getting a signal from the pick-up coil. when in the "start" mode the module controls the spark. then when it reaches 400 RPM the ECM takes over with the timing control. (then it uses the module as a triggering device.
I say the module is toast. although it is possible the coil is weak. check to see if the coil is being triggered. use a test light between the WHITE wire of the coil & ground. while cranking it should flash. if it does the coil may have a open in the primary side. if not the module is bad.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
