Old 07-06-2002, 02:25 PM   #1
big.l.a
big.l.a's Avatar
Loose Header Bolts Question
What the best way to keep the Header bolts tight. I am tring
lock washers now (Summit has some locks for $31+ thats a bit much in my oppion for some bolts) . And are the copper gaskets the best ones to get.
71 C10 LWB With
Edelbrock 7101& 1406 Carb
Accel HEI Blue Print
Accel 8.8 Wires
Soon to have possi &
186 Camel hump heads
Dropped 2-1/2F&4R
Dynomax Headers
Duals Flowtech Aftburners
Tonneau Cover Frm 89 F150
79 Monte C
big.l.a is offline   Reply With Quote
Old 07-06-2002, 02:33 PM   #2
Super Chevy
Super Chevy's Avatar
i hear those dead soft alluminum gaskets are good, after you put the new gaskets in,and warm the motor up real good go back over the bolts again and tighten them after the gaskets seat
S-C
Super Chevy is offline   Reply With Quote
Old 07-06-2002, 02:43 PM   #3
Mudder
Mudder's Avatar
Simple and cheap
Cut your flanges on each side of the center 2 tubes and use metalic manifold gaskets. You wont have no more problems.
Mudder is offline   Reply With Quote
Old 07-06-2002, 02:43 PM   #4
junkyardjohn
junkyardjohn's Avatar
Thumbs up
I'VE USED THE COPPER GASKETS WITH MIXED RESULTS. ON GOOD HEADERS, WITH A 3/8" FLANGE (HOOKER SUPER COMP. OR DOUG THORLYS) THEY WORK GREAT. BUT ON A SET OF CHEAPIE HEADERS THAT I HAD ON ONE OF MY TRUCKS, THEY WOULDN'T SEAL AT ALL. AS FAR AS THE STAGE "8" LOCKS, IT WOULD BE THE BEST $35 YOU EVER SPENT. I'VE BEEN USING THEM FOR YEARS & WOULDN'T EVEN CONSIDER RUNNING HEADERS WITHOUT THEM. I CAN'T STREES ENOUGH HOW NICE IT IS TO HAVE HEADERS THAT NEVER EVER COME LOOSE & LEAK.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-06-2002, 02:58 PM   #5
Mudder
Mudder's Avatar
Trying this pic
cut your flanges with a sawsall on the arrows. you wont have any trouble with the bolts coming loose.
Old 07-06-2002, 03:17 PM   #6
Denny
Denny's Avatar
Thanks for the tip on cutting the header flanges.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 07-06-2002, 03:21 PM   #7
mikep
Used to have a truck
mikep's Avatar
I used to safety wire everything. Habit I picked up in the military. Never had anything loosen with safety wire. I'm too lazy now but it works great. I use copper gaskets and have never had a problem with leaks.
No truck :-(
mikep is offline   Reply With Quote
Old 07-06-2002, 04:27 PM   #8
WORNBRAKES
mikep--I thought I was the only one that used safety wire on the truck. Good to know I am not. Safety wire is almost as handy as duct tape.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 07-06-2002, 04:33 PM   #9
69GMC910
MOTORHEAD!
69GMC910's Avatar
WHOA! Don't push it there WORNBRAKES, Safety wire will never come close to the almighty DUCT TAPE!!!!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 07-06-2002, 04:44 PM   #10
SCOTI
SCOTI's Avatar
A dirt cheap alternative to 'stage 8' hardware is standard lock washers & red loctite on the threads + the sectioning of the flange.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-06-2002, 05:04 PM   #11
tom hand
CCRider
tom hand's Avatar
Safety wire or loctite won't stop headers from getting loose. The bolts don't get loose, the gasket between the headers and the head compresses because of the difference between the steel and the cast iron. If you have headers, they just need to be tightened every so often, end of story. If you can't deal with it, get manifolds.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 07-06-2002, 05:19 PM   #12
big.l.a
big.l.a's Avatar
Headers
Thanks for the Good Info I would have never though of
cuting the Flanges
71 C10 LWB With
Accel 8.8 Wires
Dropped 2-1/2F&4R
Dynomax Headers
79 Monte C
Old 07-06-2002, 06:15 PM   #13
Mudder
Mudder's Avatar
IT WORKS!
I don't even check mine anymore.
Old 07-06-2002, 06:29 PM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
This has never been a problem on my Chevies either. Only my old honda...but we won't tqalk about my days when I was on the dark side.
Old 07-06-2002, 06:44 PM   #15
junkyardjohn
Thumbs up
BY TOM HAND-----THEY SURE DO. I'VE HAD HEADERS ON MY DAYLY DRIVEN BLAZER FOR 3 1/2 YEARS WITH STAGE "8" LOCKS IN PLACE & HAVEN'T HAD TO RETIGHTEN THEM YET.
junkyardjohn
DON'T RENT U-HAUL
