Its Magically Delicious
Full vacuum on rochester carb
Where can i find the correct port on a Rochester q-jet 4MV ... to get full manifold vacuum ... want to double check myself
thanks
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
blood type; Retumbo
front, top of passenger side. sometimes it has a metal "T" tube.
back of baseplate near the large port for the power brake booster connection. if I can find a cable to connect my camera-phone to the PC I can take some pics to explain.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
On my old q-jet the lower driverside pipe, Thats where the vacuum advance was on the old setup. Buy a cheap vacuum gauge at idle hookmit up to the port and you should have about 20" of vacuum, rev it up and the vacuum should drop a little, If it is ported at idle you would have no vacuum till you reved it up then it would go up to 20" then start to drop off.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
this what the front of the carb looks like right now
pass. side top ----> vacuum advance lower driver side ----> evap canister
