10-10-2005, 10:39 AM | #1 |
Just Don't Stop!
Can someone measure the inside width of the wheeltub on a fleetside for me?
I just want to know the width of a fleetside bed stock. Like the dimension from the inner tub to the inner lip of the outer fender. I was wondering if there is any truth to the fleetsides have a more room than the stepside claim.
1968 C10 build in process TT LSA/6L90e/9" |
10-10-2005, 12:23 PM | #2 |
FirstGen, they should be the same between the tubs. I can tget a measurement on my 68 after work for you if somebody doesn't beat me to it before then.
10-10-2005, 12:27 PM | #3 |
Just Don't Stop!
I wonder what it would look like to tub a step side using fleet wheel tubs? I'm sure someone has done this, anyone have a pic?
Thanks Scoti!
10-10-2005, 02:22 PM | #4 | |
10-10-2005, 03:49 PM | #5 |
just under 13" from inside edge of wheel tub to inside edge of bedside along arch. The inside of the bedside angles inward above the wheel arch and I didn't have a flashlight to look up in wheelwell to read tape. Hope it helps.
10-10-2005, 04:26 PM | #6 |
Just Don't Stop!
thanks for the reply. I think I will just use fleetside tubs. Scoti, do you have a set you want to sell me?
Thanks, Taylor
10-11-2005, 05:37 AM | #7 |
Got Big Block?
First Gen, I've got a set. I'll email you some pics in the morning. Bad luck though, I just met up with a guy from Dallas (on Saturday) and swapped 12 bolts (car) that could've brought them back to you....
"Experience is what you get when you didn't get what you wanted." |
