Old 10-10-2005, 12:59 PM   #1
COBALT
COBALT's Avatar
TH400 Going Bye-bye
Guys:
I started hearing that tell-tale whistling-whirring sound usually heard when the torque converter is starting to fail. Since I'll probably need a new one, and the transmission has a lot of miles on it anyway I think I'll be looking for a rebuilt.
I won't have time to take it out of the truck, and I won't have time to work on it myself, so I'm going to have to wheel it into a shop and have them drop it out, rebuilt it with a new torque converter, and put it in the truck for me.
Anyone know of a good shop in the Seattle area? What about the puget sound area in general? It doesn't have to be just Seattle...
Thx.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-10-2005, 07:25 PM   #2
70 net440
Junior Member
70 net440's Avatar
Check that your filter hasn't fallen off. I've seen this happen, and it makes a strange noise.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 10-10-2005, 08:33 PM   #3
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I don't know of any good ones in Seattle but try the "click and clack" website and enter your zip code. There was a guy at Monroe that specializes in trannmissions A-Z 425 397-6111. He is in Everett and his name is Bill Dettrich. He seemed nice and had a better price than I have been quoted in most shops. The best shop I have heard about in Seattle is Dukes on first avenue 206 241-5355. Many shops say they just send the trannys to Dukes to be rebuilt. Didn't you just rebuild that tranny a couple of years ago?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 10-10-2005, 09:30 PM   #4
COBALT
COBALT's Avatar
No, I just replaced the seals, and put on a new pan with a new gasket. I remember inspecting the torque converter and it looked like it was ok. I've been meaning to either rebuilt it myself or have someone do it. Right now I have no time to work on the truck besides tune-ups and such, so I'll have to send it in.
Seattle, WA.
Old 10-10-2005, 11:37 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Originally Posted by COBALT
I started hearing that tell-tale whistling-whirring sound usually heard when the torque converter is starting to fail...
Does this sound seem the worst when loading it up...say, trying to creep slowly up a steep driveway without spinning the tires?
Is there a way to verify it as being the converter?
Is it obviouse that i am concerned about my tranny since it is making a similar noise?
Old 10-11-2005, 12:04 AM   #6
cableguy0
it sounds like it could be either the sprag or the convertor going out. not to hijack but andy im amazed that th350 is still working behind that big caddy motor. you need a th400 badly. but anyways even if the convertor is going bad when they do go bad they put metal through the trans trashing everything else. by the time a converter wears out the trans is worn equally as much and needs rebuilt as well
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-11-2005, 12:26 AM   #7
Longhorn Man
Well, this tranny has only been hooked to the 500 for about 1200 - 1500 miles, and to the 425 for less than 200 miles.
Plus, the converter is out of a TH400, so the age of the converter is a moot point as far as the tranny age is concenred.
I have yet to tow anything, haven't hauled more than 1200 pounds, and in all reality, I don't rag on it too much. Granted, i have gotten into the throttle a few times, but nothing REAL severe.
Old 10-11-2005, 12:29 AM   #8
cableguy0
believe me it only takes ONCE my sb was eating th350's left and right for a good while i broke the front sprag and the low reverse sprag a couple times. ripped low reverse sprag outta the case that was neat. that th350 needs more than the stock sprag to think about living behind that big caddy.
Old 10-11-2005, 01:36 AM   #9
COBALT
COBALT's Avatar
The reason why I think it's the torque converter is that the sound is worse during warm-up when the RPMs are high and pressure in the transmission case is at it's lowest. It doesn't seem to be better or worse under load at all. It'll do it sitting still from a cold start.
I'm thinking both halves of the converter are rubbing together, which means the lock-up clutch in the center is warn out. Any debris dropped by the converter will contaminate the valve body of the transmission over time. It's seen a lot of miles even before I bought the truck in 2001. Then it was the best thing in the truck before I did all of the work to get it running. I've been suspecting it's due for a rebuild for a while now. I've been babying it for 30,000 miles, and it saw some serious miles before that, so I think it's seen it's limit.
Seattle, WA.
Old 10-11-2005, 11:39 AM   #10
grebus1
grebus1's Avatar
I've heard good things about Village Transmission in Edmonds. I haven't had any work done there myself, but they're close to my home and that's probably where I'd start if I needed tranny work done.
www.villagetransmission.com
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 10-11-2005, 12:24 PM   #11
cableguy0
th400's dont have a lock up clutch in the converter.you could be hearing the bearing between the two halves starting to go bad. theres numerous things in the transmission that could make that noise.
Old 10-12-2005, 12:39 AM   #12
67sss
67sss's Avatar
Skagit Transmissions on Lila Lane in Burlington. That's where everybody here in the valley takes their stuff. They've been in business for e-ons. Or my house, got a 400 shortshaft(I think) for $75, came out of a mid 80's Z-28.
67sss is offline   Reply With Quote
Old 10-13-2005, 01:55 AM   #13
COBALT
COBALT's Avatar
Exactly. That's what I was thinking. Doesn't matter what gear I'm in (D, L1, L2 or R), which means the valve body, the reverse band, and the two clutch drums are probably not involved. It doesn't sound like the pump bushing going bad, but it very well could be the pump. That also leaves the torque converter. It's one of the two I think.
...and no I'm not in the market for another transmission. I have three to work with, but this is the one in the best shape. The others I have are for me to rebuild whenever I have time...whenever that is.
Thanks for the help. I'll go make some calls.
Seattle, WA.
