Old 10-10-2005, 01:43 PM   #1
phlegm
Still Green but learning
phlegm's Avatar
AC Compressor Question,
My clutch is out on my AC Compressor. A buddy has an old compressor that is shot, but has a good clutch on it and is willing to give it to me. Trouble is we cannot figure how to get the clutch off? Any tips?
At this point I am thinking replace the entire unit with a 100.00 Autozone reman.
O yea, this weekend my points went bad, guess how I found out?? Nothing like point replacement on the interstate in the rain, Yee Haw... and the oil leak on Valve covers was fixed, again and right this time... I think.
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 10-10-2005, 02:05 PM   #2
john
member #16
john's Avatar
You will be better off with the reman comp. It takes special tools to remove and install parts on front of comp. John
john is offline   Reply With Quote
Old 10-10-2005, 02:08 PM   #3
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Needs a special tool. Looks kinda like this. http://www.tooldesk.com/products/pro...l.aspx+id+1762
Can't remember where I bought mine. Think Napa.
Edit: I went ahead and bought the tool. It was cheaper than paying for a whole compressor and having it serviced.
chickenwing is offline   Reply With Quote
Old 10-10-2005, 02:13 PM   #4
phlegm
phlegm's Avatar
Very cool, thanks guys!! This board Rocks.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-10-2005, 04:11 PM   #5
phlegm
phlegm's Avatar
Started surfing the removal tool and found it pretty cheap, there is an installation kit as well... Do I need special tools to install too?
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-10-2005, 10:11 PM   #6
phlegm
phlegm's Avatar
Bump, tool or compressor, that is the question.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-10-2005, 10:31 PM   #7
Blue4x4
Blue4x4's Avatar
If it were me...I'd buy the reman compressor. Just think of all the work that could be done and have the possiability of a bad compressor seal. I do heat and ac for a living and have all the tools to the job that most people aren't able to.
Blue4x4 is offline   Reply With Quote
Old 10-10-2005, 10:36 PM   #8
phlegm
phlegm's Avatar
Blue, you are my hero, not just for the advice. I used to ski competitively in college, and once married found more time for trucks the the lake. That looks like an awesome rig in you avitar, send me the larger pic.
cory@deanhardt.com
Thanks for the advice, I will take it to heart, trick here is the clutch hub was free off a bad comprssor, so 25.00 for the tool or 100.00 for the compressor. If I need special tools to reassemble I will have to pass.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-10-2005, 11:07 PM   #9
Fred T
Cantankerous Geezer
Fred T's Avatar
Some parts stores will rent the tools, but not all have the ones for the a/c clutch. It would probably be worth a phone call.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 10-10-2005, 11:33 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
For what it's worth I made a tool for this. I used an NPT pipe bushing that threads into the clutch I think it was a 1/2 in. pipe and I simply welded a 3/8ths by 16 nut onto the bushing. Then any 3/8ths x 16 bolt with enough threads to hit the compresser shaft will work. I removed the clutch nut with my impact driver and threaded it back onto the shaft far enough to protect the compressor shaft threads then just ran the 3/8ths bolt in till it hit the nut and broke the clutch seal. I'm typing this from memory so the sizes may not be quite right but I just wanted to give you an idea if you feel like trying it. I know that buying the tool from the store may be the proper way to do it but I like making my own stuff. Total cost was zero. If I had to buy a new clutch then I'd have bought the new compressor with the clutch already on it. Good luck.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-11-2005, 01:56 AM   #11
crustysarge
I just changed mine a few months ago. I wound up buying a rebuilt compressor with clutch because the clutch was around $70 and the comp w/clutch was $99. I bought a puller/installer on Ebay (Snap On) for $50. I wanted one anyway so it gave me a reason to buy it.
My system still has R-12 and was OK so I did not want to bust it open. I used the puller to remove the clutch from the new comp, took about 5 minutes.
I then unbolted the comp on the truck to move it back some so I could access the clutch with the puller. I pulled the old one off and it was cooked. You need the tool to install the new one and need to set the air gap. Very simple and whole process took me about 90 minutes with beer breaks.
Installing the clutch, go slow and use a feeler guage to set the gap between the clutch and comp. I believe I got it to about 15 thousand or so and it was uniform all the way around. You want it as close as you can get it. If you go too far, just reverse and pull it back up a bit and then install again.
Trust me, it is not hard to do and I personally think it beats opening a perfectly good sealed system which means vacum and the whole thing. If you open, be sure to change the drier as well.
Plus, I have a rebuilt comp that I can sell for maybe $50 or so or just keep for a spare.
crustysarge is offline   Reply With Quote
Old 10-11-2005, 12:43 PM   #12
phlegm
phlegm's Avatar
So if I understand correctly, if I change the compressor the steps would be vent the system pull compressor, replace compressor. Pull Drier, replace Drier. Put coolent back in system. No need to vaccume if I replace the drier right?
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 10-11-2005, 01:06 PM   #13
john
member #16
john's Avatar
when ever you open A/C system to the atmosphere you have to evacuate(pull vacuum) system. That removes all moisture from system before charging, along with new drier. Hope this helps. John
Old 10-12-2005, 03:52 PM   #14
/<eystroke
/<eystroke's Avatar
Does anyone know if they made different belt sizes for AC compressors? My remanufactured compressor has a slightly larger V than the belt likes. It runs on the bottom of the V instead of the sides. The belt fits correctly on the crank shaft pully. Is it a different size or just wore out? I've looked for slightly larger belts but nobody at the parts store seems to know anything.
'69 C/10 Short Wide
350/400/AC/Tilt/Tach
/<eystroke is offline   Reply With Quote
Old 10-12-2005, 04:20 PM   #15
cdowns
cdowns's Avatar
keystroke/// try going to a lawnmower place for the bigger belt size
Old 10-13-2005, 08:58 AM   #16
phlegm
phlegm's Avatar
Hey Sarge, in evaluating the options, i think I am going to make/find a tool and replace the clutch hub. A friend of mine will donate one off of a shot compressor to me. The removal Tool I Have been able to find on line, does it also assist in installation? what did you use and how to install the old hub?
How cool is truck advice from italy?
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
