Old 10-10-2005, 02:00 PM   #1
70GMC_BOB
Need Wiring diagramhelp!!
My dad and I rebuilt the 350 and got the engine re-installed last weekend in my 72 chev 3/4 ton 2wd truck(w/ HEI). When we initially tried to start it it cranked then backfired and lost all power(no lights or anything). I believe it blew a inline fuse. I need a wiring diagram for the engine for a reference. I do have the wiring diagram for a 69 but do not know if they are the same?
I also need a wiring diagram of a hei modification as it was already installed when I bought the truck.
I am going to start troubleshooting today after work.
I forgot my camera when we installed. I will post pics when it is back at my house.
70_GMC_BOB
1972 chev c20 2wd lwb 350v8/th350. (dad's)1970 gmc longstep (9ft commercial bed), 1 ton, 2wd, 350/th400.
70GMC_BOB is offline   Reply With Quote
Old 10-10-2005, 02:06 PM   #2
70GMC_BOB
I found this post on classic heartbeat with a engine comp. wiring diagram. So now I am looking for the HEI modigfication diagram.
http://www.classicheartbeat.com/foru...wiring+diagram
Old 10-10-2005, 02:15 PM   #3
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I am not aware of any "fixed" way to do the HEI mod. You NEVER know how the PO did it until you unwrap the harness! You only need a keyed 12v supply. Think there is a write up in the FAQ's if you want a good way to do it.
chickenwing is offline   Reply With Quote
Old 10-10-2005, 02:19 PM   #4
70GMC_BOB
I found the HEI info on classicheartbeat.com As well. If anyone has a diagram or more info it would be appreciated.
http://www.classicheartbeat.com/forums/showthread.php?
t=3265&highlight=DISTRIBUTER
Old 10-10-2005, 02:21 PM   #5
70GMC_BOB
Just for the record the engine was at TDC and the distributr was pointing to #1 with the vac. adv. pointing cyl #1. Is htis the correct setup?
