Old 07-06-2002, 04:11 PM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Tdc, Where Is It!
I seem to be having trouble following the directions given to me by bigvinnie. In the notes he hyperlinked me it says that TDC should occur right after the intake valve closes. This occurs nowhere near the timing mark on the balancer. Just as I am coming up to TDC my exhaust valve has just closed. What is going on here, I think it's something simple but the heat is getting to me.
Help please!!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 07-06-2002, 04:16 PM   #2
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
Smile
I believe that when you are at TDC, both valves should be closed. Take #1 spark plug out, hold finger over hole and have someone bump the ignition turning over motor until it blows your finger out. You're mark on balancer should then line up. Hope this helps.
Mitzki5
No longer have an old truck! But always looking for another one!
Mitzki5 is offline   Reply With Quote
Old 07-06-2002, 04:19 PM   #3
69GMC910
MOTORHEAD!
69GMC910's Avatar
Both valves are closed at the moment, I haven't got the Intake on so it is really easy to see what is happening. Just to clarify, the intake valve is the second from the front on the drivers side right?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 07-06-2002, 04:22 PM   #4
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
Yes, To be sure, just look and see where your exhaust comes out.
Mitzki5
Old 07-06-2002, 04:28 PM   #5
69GMC910
MOTORHEAD!
69GMC910's Avatar
What I don't get is how can the ignition fire at TDC on the exhaust stroke, it's not possible. Is my timing mark 180 degrees off or something?????
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 07-06-2002, 04:30 PM   #6
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
You probably have dist in 180 deg off. Did you just put in the dist.
Mitzki5
Old 07-06-2002, 04:35 PM   #7
69GMC910
MOTORHEAD!
69GMC910's Avatar
Intake is not on, distributor is not in, trying to time the valves without all that stuff in the way.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 07-06-2002, 04:41 PM   #8
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
Ok, do this at your own risk. You could possibly strip bolt on crank and that wouldn't be good. Take out #1 spark plug. Place finger over #1 plug hole. Put ratchet on bolt that holds balancer on. Turn clock wise until you get compression. As soon as mark on balancer lines up with compression in cylinder, you should be at TDC. I hope I explained this right. This is how I got mine at TDC. Don't force the balancer bolt. I don't want you to strip those threads.
Mitzki5
Old 07-06-2002, 04:43 PM   #9
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
If you have someone to help they could turn the motor over by the fly wheel. Need to be fairly strong and wear gloves. Make sure you turn it the correct direction.
Mitzki5
Old 07-06-2002, 04:43 PM   #10
69GMC910
MOTORHEAD!
69GMC910's Avatar
Okay, I'll try that then, thanks mitzki5!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 07-06-2002, 04:44 PM   #11
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
Good luck and post what you come up with. Later
Mitzki5
Old 07-06-2002, 04:53 PM   #12
tom hand
CCRider
tom hand's Avatar
OK I got ya, intake not on, distributor not in. I always adjust the valves at this point. Use a wrench and turn the motor over. When the intake valve opens, that is the intake stroke. When both valves close, that is the compression stroke, use a pencil in the sparkplug hole to see when it is at the top of the stroke,and that is TDC. If your balancer is in time you can use it to get to zero. Confused yet? Hope this helps.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 07-06-2002, 06:05 PM   #13
greasemonkey
greasemonkey's Avatar
Eastwood has a whistle you screw into the spark plug hole, you turn the engine and the compression whistles through it. When you reach TDC it stops. Kinda corny but I don't see why it wouldn't work. Good luck.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 07-06-2002, 06:15 PM   #14
69GMC910
MOTORHEAD!
69GMC910's Avatar
Okay, It must be the 32 degree weather messing with my head! that's about 90F for the imperial guy's. TDC was right where it should be on the flywheel with both I and E valves closed. So I was adjusting the rockers and everything was going swell until I got finished and checked them all again by hand. Some of them were loose again, is this because I drained the oil pressure out of the hydraulic lifters?????
Thanks for all your help guy's
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 07-06-2002, 06:43 PM   #15
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
I believe they will loosen some due to bleeding the lifters.
Mitzki5
Old 07-07-2002, 08:40 PM   #16
jlmtrout
Just a thought, could you have jumped a tooth in your timing gear? Good luck and keep on truckin'!-----------Jerry
P.S. When you ask people for help,
don't get pissed when they ask
questions you may find insulting
to your ability. We weren't there
when it broke and don't know
any more than what you tell us
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 07-08-2002, 01:05 AM   #17
Blue68
Blue68's Avatar
Yes the lifters will bleed down when you go back again.
It is a bear to find TDC with the dist out. You'll need to watch your valves closely and turn the crank the correct direction.
You will find it CONSIDERABLY easier to turn the engine with all the plugs out. As in by hand with no problems. If you have the timing cover off it is easy as well.
You make the comment====
"What I don't get is how can the ignition fire at TDC on the exhaust stroke, it's not possible. Is my timing mark 180 degrees off or something?????"
Yes, you are missing something. Something very important, the crank rotates twice to each rotation of the cam. Thus your piston goes up and down twice to each rotation of the cam. Once is the intake/compression stroke and the other the combustion/exhaust stroke. It is not my intention to talk down to anyone who knows this, but everyone gets confused about something some time in their lives.
Now what were we talking about?
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 07-08-2002, 01:16 AM   #18
Sinister
Between Trucks...
Sinister's Avatar
if ya got the front cover off,
you can check the marks
on the cam and crank timing gears...
if there facing each other i believe that's TDC...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-08-2002, 12:13 PM   #19
johnnyp
Keepin' It Stock
johnnyp's Avatar
A picture's worth a . . . . well, you get the idea:
http://www.howstuffworks.com/engine2.htm
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
