Old 10-10-2005, 05:08 PM   #1
72 longhorn BB
72 longhorn BB's Avatar
HEI harness problem
Does anyone know why this HEI connector has a 2 into 1 plug?
I got it from a late model donor for my 72 C-20 HEI conversion and I always thought that the HEI needed two separate wires - one for power and one for tach.
I really got this off an HEI, but I think I got the wrong one, or did I?
Can someone help me out?
Chuck
1972 C-20 Longhorn
402 BB .030" over (409?), curved HEI,
RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit
1999 K1500 Suburban (old style)
5.7L Vortec
4L60E
"No matter where you go, ........ there you are"
Last edited by 72 longhorn BB; 10-10-2005 at 05:10 PM. Reason: image tag was wrong
72 longhorn BB is offline   Reply With Quote
Old 10-10-2005, 05:15 PM   #2
beaterC10
Looks like you have the adapter to power the ESC module on the 80's trucks. Since you aren't using the ESC, you can ignore the adapter.
beaterC10 is offline   Reply With Quote
Old 10-10-2005, 05:48 PM   #3
Starscream
Starscream's Avatar
Do you have a tach.
Starscream is offline   Reply With Quote
Old 10-10-2005, 08:32 PM   #4
72 longhorn BB
What is ESC?
I'm curious now.........I thought that an HEI would always have the same connector plug, but I guess from what you are saying, the later (80's) versions had this ESC system. What is it?
Also, I currently have no tach, but am planningon getting one.
Why do you ask?
Chuck
1972 C-20 Longhorn
5.7L Vortec
4L60E
Old 10-10-2005, 09:17 PM   #5
beaterC10
ESC is electronic spark control. I had that on both an 83 and 84. They both had the adapter like you have. The tach connection is a separate connection on the cap. I would assume the adapter could be used for anything on the truck that had a spade connector.
Old 10-11-2005, 10:03 AM   #6
86 GMG
beaterC10 your are correct 83 and 84 i have an 84 that i just had to rebuild the dist. the dist. also has two pig tails or wire harness coming ut of the metal part of the dist. i believe you can cut two wires and jump the to gether and then you can use that dist but without these wire connected to the esc or jumped across it will not fire this is really all i know about these b/c like you i thought all hei's are the same until i messed with mine you can use the one you have but you will need a buddy that knows what wires to cross for sure and if thats not available than another dist. will be needed best luck and i hope i didnt confuse you due to me not knowing all about these types of dist.
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
