10-11-2005, 02:32 AM | #1 |
What kind of tranny is this?
Can you please tell me what kind of tranny is this?, is mounted to a 292 L6 1968 chevy short bed mexican truck. Can i just swap this for a th350?
I am trying to repair the AC control assy, i have the replacement arms but no idea where to cut or drill, so if you have a diagram please share to me.. Thanks |
10-11-2005, 02:51 AM | #2 |
Gone Fishing
Looks like a granny four speed to me
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
10-11-2005, 06:54 AM | #3 |
The automatics have their own cross-member,you`ll need that.
10-11-2005, 08:45 AM | #4 |
looks like an 4 speed granny transmission to me there good trannys had one in an work truck and it would pull anything around work
10-11-2005, 08:57 AM | #5 |
Where are you in Mexico? Maybe I can help. I've done the swap and can give advice or if you are close lend a hand.
You will need: 1. Cross-member from auto truck 2. Remove manual cross member 3. Vacuum line to modulator from carb 4. Kick-down cable set up My swap went well. I installed a Hurst floor shifter rather than trying to replicate the shifter on the column. GOOD LUCK ! |
10-11-2005, 01:47 PM | #6 |
Questionable
I have a similar tranny in my garage right now, it's a 4spd. Been trying to get rid of it forever.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
10-11-2005, 03:18 PM | #7 |
It's a catastrophic success.
might help.
10-11-2005, 04:42 PM | #8 |
Questionable
The 4spd in my garage looks like a SM465 or the NP435.
10-11-2005, 04:43 PM | #9 | |
'68 C-20 396 CST CC
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES 01 Jetta Turbo Daily Driver 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico |
10-11-2005, 07:12 PM | #10 |
Im gonna say its the SM465, cuz my NP435 doesnt look like that on the left side
-Steve |
10-11-2005, 08:06 PM | #11 |
its all about the +6 inches
Don't forget a tranny cooler too in addition to the list above.
10-11-2005, 09:46 PM | #12 |
Good call LongHorn ! I forgot about that new radiator with the cooler built in I had to buy! A good add-on would also work if the radiator he has now doesn't need replaced.
10-11-2005, 10:03 PM | #13 |
hey shifty your 4 speed is it granny if i not how much u want for it?
10-11-2005, 11:27 PM | #14 |
That is a 435----just like the one in my 68 GMC. The 4 bolts on the back holding the output housing is the give away.
10-12-2005, 10:57 AM | #15 | |
Questionable
I bought it from another board member down in Orlando for between $100-$150 (I forget). I have most of the brackets and crap that came with it. Need to get it off my hands. I can shoot you some pics if you want.
10-12-2005, 11:06 AM | #16 | |
10-20-2005, 03:21 AM | #17 |
Re: What kind of tranny is this?
Mr. KWMECH, do you know if this tranny (435) has somewhere a place to put the back up switch?
10-20-2005, 07:16 AM | #18 |
the back up switch is located on the top left corner maybe broken off
10-21-2005, 01:25 AM | #19 |
The steering wheel is not new, i have restored it, polished and painted the cap, even the model is a 1969 in Mexico the steering wheel came with this kind of cap 69 thru 72 models. Another diference is the bed, complete diferent the rear wheel arch is square not like in circle. I have some photos but do not know why i can not post it anymore..
I have looked the top left corner and nothing, any photos? |
10-21-2005, 02:51 AM | #20 |
Designated A-hole!
Gonna have to add that pic to the FAQ thread.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-21-2005, 09:08 AM | #21 | |
Where's my beer?
Does your bed look like this one?
Paul How do you make the invisible, visible?.........You take it away. |
10-22-2005, 12:43 PM | #22 |
Yes!!!!! it looks like my wood bed, the bad thing with this kind of bed is the upper union, in my place with a lot of humidity that union gets alot of rust, i am trying to put the other type of bed. Do you know if these beds were build only for trucks outside the states?
10-23-2005, 07:40 AM | #23 | |
Yes, they never sold that type of bed in the US.
Tim |
10-24-2005, 10:48 PM | #24 | |
Questionable
Ok, so I know more now. It's an SM465 for sure and it has a torque converter attached. According to a website I found about the tranny, here is the info: The Muncie 465 is the widest ratio 4-speed of the Big Three. It has a granny low and so then just 3 normally usable ratios. Here are the gear ratios from drivetrain.com: 1st :: 6.55 2nd :: 3.58 3rd :: 1.7 4th :: 1
10-24-2005, 11:07 PM | #25 |
Those beds were shipped in pieces,then assembled in Mexico.Trucks were cab`n`chassis,bed option.
