Closed Thread
Old 10-11-2005, 07:57 AM   #1
Dean
Dean's Avatar
New 87 K30 Project
Here is my latest project....1987 K30 454, NP205, 4.10 gears, etc etc. I will be doing a body swap on this one also. Most likely this complete blue body will be for sale in the near future unless someone local buys it first. It is in pretty solid shape rust wise and would only need rockers. I'll be buying a crate 502 engine and a 4" lift for this one also.
I'm looking for some 8 lug aluminum wider wheels, big block exhaust manifolds, new style air conditioning compressor brackets for big block and etc it anyone has any leads.
Dean is offline
Old 10-11-2005, 11:00 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Dang! That is sweeeeet!
I've got a pair of stock manifolds that came off an 89 1 ton 2wd, I will try to dig up pics for you. I don't know if the 2wd manifolds are different, I would imagine they are.
I just might have the air conditioning bracket(s). I'm pretty sure I do. I will check tonight and get you pics.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline
Old 10-11-2005, 12:44 PM   #3
Dean
Dean's Avatar
Sounds good. I'm not sure what the differences are in these big block manifolds. I'd love to see a picture of a K30 with factory manifolds. Maybe I can make the ones you have work.
I'm not sure where the air conditioning bracket would have been on a 87 K30 either. I'm moving my C20 body over on it which has A/C but on a 350. Surely it would work?
Like the silicon header patch the previous owner did? Like that stopped all the 101 leaks.
My email address is djhauck@fuse.net.
Dean is offline
Old 10-11-2005, 07:26 PM   #4
87_Blazer
Getcha' Pull!!!
87_Blazer's Avatar
i am in love with your truck
Rest In Peace Dime
87_Blazer is offline
Old 11-04-2005, 10:53 AM   #5
Dean
Dean's Avatar
Re: New 87 K30 Project
It looks like I'm in need of a frame crossmember for a 1 ton. Need the crossmember under the bed that goes across by the front of the rear springs. Needs to be a 1 ton since the frame is taller than a 3/4 ton. My C20 has part of the same crossmember but not all of it.
Also, does anyone know what the wire does going to the NP205 transfer case? light? lockout?
Dean is offline
Old 11-04-2005, 11:42 AM   #6
leadfoot067
horsepower junkie
the wire is for the 4wd indicator light on the dash....
67 short wide box,350/700r4/3.73posi
71 olds cutlass "S" mom bought new..12.30s@113MPH
leadfoot067 is offline
Old 11-16-2005, 08:35 AM   #7
Dean
Dean's Avatar
Making progress. Bed removed.
Dean is offline
Old 11-16-2005, 08:36 AM   #8
Dean
Dean's Avatar
Body removal.
Dean is offline
Old 11-16-2005, 08:38 AM   #9
Dean
Dean's Avatar
Old body sitting on my dolly. Happens to be an old 1920's Autocar frame.
Dean is offline
Old 11-16-2005, 05:24 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Dang, that is a sweet setup - one of these days a lift just has to find its way into my shop! Glad to see progress is going well. Do you think the manifolds I sent you will be useable?
Old 11-16-2005, 11:07 PM   #11
qksilver
what are you going to do with the old BB?
Let me know.........Pm me
Thanks,
Steve
qksilver is offline
Old 11-23-2005, 08:54 PM   #12
Dean
Dean's Avatar
I've come across some more parts that I need. Let me know if anyone has any ideas.
1. K30 454 fan shroud
2. K30 emblems (Scottsdale or Silverado)
3. Frame crossmember my front rear spring hangers
4. Turbo 400 kickdown switch assembly
5. Four core radiator holder hardware
I'm sure there will be more
Thanks!
Dean is offline
Old 11-23-2005, 09:28 PM   #13
1967k30
1967k30's Avatar
I believe I have a fan shroud.Out of an 80' K30 4x4 454.Let me know if you're interested.
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline
Old 11-23-2005, 11:26 PM   #14
1Ton
1Ton's Avatar
Nice truck.
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline
Old 11-24-2005, 06:20 AM   #15
Mudder
Mudder's Avatar
All looking for or wanted to buy posts should be in the for sale forums. You need to be a subscriber to post those.
Mudder is offline
Closed Thread
